Shelby Nick Posted July 11, 2016 Report Share Posted July 11, 2016 My new Apex Wheels were just delivered! Now on to tire selection! Nick Quote Link to comment Share on other sites More sharing options...
BLD MOVS Posted July 19, 2016 Report Share Posted July 19, 2016 Those are really sharp. Where did you buy them? Quote Link to comment Share on other sites More sharing options...
Shelby Nick Posted July 20, 2016 Author Report Share Posted July 20, 2016 (edited) You can find them at apexraceparts.com. They are the EC-7 on sale for $229 and only weight 21.5 lbs. Very similar to the BBS wheels. They are 18/9.5, half a pound heavier but half the price! Nick Edited July 20, 2016 by nnadelizi Quote Link to comment Share on other sites More sharing options...
39Mustang Posted July 20, 2016 Report Share Posted July 20, 2016 You can find them at apexraceparts.com. They are the EC-7 on sale for $229 and only weight 21.5 lbs. Very similar to the BBS wheels. They are 18/9.5, half a pound heavier but half the price! Nick I was about to say similar huh they are exact copies and how BBS lets these companies get away with this is shocking Quote Link to comment Share on other sites More sharing options...
Larry T Posted July 20, 2016 Report Share Posted July 20, 2016 Share pictures when you have them on the car. Quote Link to comment Share on other sites More sharing options...
Shelby Nick Posted July 20, 2016 Author Report Share Posted July 20, 2016 I will post some complete pictures as soon as I get the tires. I am still deciding on tire size, 275/35/18 vs 275/40/18. These are suppose to be for the track but I'm sure I'll put a few street miles on them. With the 35's I will have to make or buy a ramp to get up and down the driveway. I did install one on the front just to check clearance and there was plenty. Here is a few pictures of wheel only. Quote Link to comment Share on other sites More sharing options...
03 DSG Snake Posted July 27, 2016 Report Share Posted July 27, 2016 Look a lot like the FRPP BBS wheels. Hopefully they're strong. What size tires are going on? Quote Link to comment Share on other sites More sharing options...
Shelby Nick Posted July 27, 2016 Author Report Share Posted July 27, 2016 I am struggling between 275/35/18 or 275/40/18. I understand the 35's will handle better on the track but it might be a little difficult on the street because the car sits low already. I will need to drive to and from the track and maybe a car show now and then if I don't feel like changing the wheels. I do plan on keeping the Razors. Nick Quote Link to comment Share on other sites More sharing options...
bnoslo Posted July 27, 2016 Report Share Posted July 27, 2016 (edited) Just wanted to comment about the tire sizes. Since these wheels are the same size as the stock GT500 wheels from '07-'09, you can use those sizes as a reference. Those were 255/45-18 in front and 285/40-18 in the rear. This should actually be a good setup for both street and track, if you choose to use these for both, and it gives you a larger tire in the rear for some good traction at the track. Just a thought. Nice wheels by the way, they look really good around those Wilwoods. Edited July 27, 2016 by bnoslo Quote Link to comment Share on other sites More sharing options...
Shelby Nick Posted July 27, 2016 Author Report Share Posted July 27, 2016 Thanks for your input! Definitely something to consider! Quote Link to comment Share on other sites More sharing options...
GT500-2007 Posted July 27, 2016 Report Share Posted July 27, 2016 The thing is that you can run 275/35-18's on all four corners which makes managing track tires a whole lot easier. I use to run the GT500 staggered setup but switched to 275/35-18's on all four corners and did not see a big difference in rear end handling on a road course. However I found that the wider front tire helps with handling on the heavy front end. Also there are a few options for track tires at the 275/35-18 size. To date I have not found a large selection of 275/40-18 track tires. Just my two cents... GT Quote Link to comment Share on other sites More sharing options...
MMcGuirk Posted July 27, 2016 Report Share Posted July 27, 2016 Few thoughts... Staggered tire fitment with make your car push on a road course Make sure that the 275 35 18 tires have the load rating to handle a Mustang. They are less than 26 inches in diameter(S197 cars spec a 27 inch tire) and are typically designed for lighter cars. People who run 275 35s wear them out quick. At the level you are tracking, NT 01s or R888s are a great choice...available in 275 40 18, tons of grip and acceptable tire wear - they are both a 5k mile rated tire. Quote Link to comment Share on other sites More sharing options...
Shelby Nick Posted July 27, 2016 Author Report Share Posted July 27, 2016 Points well taken! Thanks! Quote Link to comment Share on other sites More sharing options...
Lynno Posted July 28, 2016 Report Share Posted July 28, 2016 (edited) Hay Bud, these wheels fit your big brake kit nicely. I really like them. Great choice. Your Razors fit the big brakes are they 18/9's. Possible availability? Edited July 28, 2016 by Lynno Quote Link to comment Share on other sites More sharing options...
Kevin Patten Posted July 28, 2016 Report Share Posted July 28, 2016 My suggestion to you Nick is to go with the 275/40-18 in a Nitto NT01 if you're going to use them for track - they will last you a while and will aid you in building up your driving skills along with not taking alot out of your budget. Once you get used to the grip and feel of a comp tire then you may to decide to go to another tire higher up on the scale. JMO Quote Link to comment Share on other sites More sharing options...
Blown Away Posted July 28, 2016 Report Share Posted July 28, 2016 They look good Nick! Quote Link to comment Share on other sites More sharing options...
Shelby Nick Posted August 6, 2016 Author Report Share Posted August 6, 2016 (edited) I got the wheels installed yesterday. I ended up going with 275 x 40 x 18 Nitto NT05 tires on all four corners. Considering my budget and my beginner status I decided to go with 05's over the 01's. As I improve and wear them down I'm sure the 01's will be my next set of tires. Here are a few pictures. Thanks for all of your input. Edited August 7, 2016 by nnadelizi Quote Link to comment Share on other sites More sharing options...
MMcGuirk Posted August 8, 2016 Report Share Posted August 8, 2016 Nice! Quote Link to comment Share on other sites More sharing options...
gtup1 Posted August 9, 2016 Report Share Posted August 9, 2016 Very Nice!! Quote Link to comment Share on other sites More sharing options...
EL SHELBY Posted August 10, 2016 Report Share Posted August 10, 2016 (edited) Great choice! I've been torn between the Apex and the enkei PF01 myself. The PF01 is marginally lighter over the Apex. I already run the Nitto NT05 in 275/40/18 on my current wheels, Alcoa's, which are WAY too heavy for the track. The NT05 is a decent tire, I heard its good on the track but not great. I will go to the NT01 when I'm ready to replace the NT05 And possibly a 285/35/18 for a slightly larger contact patch. I would love to have 18x10.5 to 18x11 on all four corners with a 295/35/18. But then I'm looking at $400+ per wheel. Edited August 10, 2016 by EL SHELBY Quote Link to comment Share on other sites More sharing options...
Shelby Nick Posted August 10, 2016 Author Report Share Posted August 10, 2016 Thanks! Nice car El Shelby! It's amazing how the lighter wheels feel on the car. My son moved to North Dallas recently. Maybe I'll join him someday! Quote Link to comment Share on other sites More sharing options...
