rsfdiver Posted December 28, 2015 Report Share Posted December 28, 2015 Looking for a door panel insert option. I looked for carbon fiber, N/A. SVE has a plastic version but doesn't fit right. My interior guy wants $185 per door to replace with similar material and install. I know I am not the only one with this problem and if you have a 2005 to 2007 mustang yours will come off too. So what to do? Why no carbon fiber or better inserts? Help would be appreciated Quote Link to comment Share on other sites More sharing options...
2007red40thGT500 Posted December 29, 2015 Report Share Posted December 29, 2015 no, you're definitely not the first. google it and read all the results. there are a few aftermarket options but nothing too great, or easy, in my opinion. i took mine off and glued them with automotive goop but its not perfect. i'll probably have mine upholstered at some point in the future. Quote Link to comment Share on other sites More sharing options...
07gt500conv Posted December 29, 2015 Report Share Posted December 29, 2015 I continue to glue mine back. With convertible and top down all the time, our Florida sun does havoc on them... Good Luck Quote Link to comment Share on other sites More sharing options...
NorthSnake Posted January 11, 2016 Report Share Posted January 11, 2016 (edited) Carefully tape off the door plastic, the use quality 3M or Permatex spray adhesive on both the vinyl and door backing parts, then carefully roll it up and back in place once both pieces have set to "tacky". This worked nicely for me, no problems after 2 years and they look good as new. Use a plastic upholstery wedge or even a plastic spoon to tuck in the edges. Just make sure to mask the car well, I used blankets and old sheets to help. Edited January 11, 2016 by NorthSnake Quote Link to comment Share on other sites More sharing options...
07gt500conv Posted January 12, 2016 Report Share Posted January 12, 2016 When mine happened the first time, my buddy at the body shop did exactly what you said Quote Link to comment Share on other sites More sharing options...
