donc Posted February 2, 2013 Report Share Posted February 2, 2013 I received my brake duct/light bezels and PIAA driving lights today. Can someone tell me how to remove the off road truck looking plastic grill from the light? Does it just pull off? Link to comment Share on other sites More sharing options...
shelbymotorsports Posted February 2, 2013 Report Share Posted February 2, 2013 I received my brake duct/light bezels and PIAA driving lights today. Can someone tell me how to remove the off road truck looking plastic grill from the light? Does it just pull off? Yes its a snap on (& off) plastic grille. Steve Link to comment Share on other sites More sharing options...
donc Posted February 2, 2013 Author Report Share Posted February 2, 2013 Steve-- That worked perfectly. Thank you. Link to comment Share on other sites More sharing options...
Steve.Madrid Posted February 3, 2013 Report Share Posted February 3, 2013 What diameter are the lights? I have seen a few different measurements. Thanks. Link to comment Share on other sites More sharing options...
donc Posted February 5, 2013 Author Report Share Posted February 5, 2013 They measure 4" in diameter. Also, the light kit has generic manufacturers instructions but no specific Shelby instructions for installation on SGTs. Link to comment Share on other sites More sharing options...
Jer Posted February 5, 2013 Report Share Posted February 5, 2013 They measure 4" in diameter. Also, the light kit has generic manufacturers instructions but no specific Shelby instructions for installation on SGTs. http://www.teamshelby.com/installation/bezel_lowershelbygt.pdf Jer Link to comment Share on other sites More sharing options...
Steve.Madrid Posted February 5, 2013 Report Share Posted February 5, 2013 donc/Jer Thanks for the info. I have seen diameter measurement info from 3.5 to 4.0 now. I like the PIAA lights but to be honest I am trying to see if there is a suitable option which is less expensive. I would hate to have one damaged and replace at close to 200.00 for what is truly an asthetic more than functional/useful mod. Link to comment Share on other sites More sharing options...
EL SHELBY Posted February 5, 2013 Report Share Posted February 5, 2013 If I'm not mistaken I believe the brake duct opening is 3.5". I've wondered if it's possible to use a 3.5" light in that opening and then use the original light opening for the brake duct. Making a swap might cure the issue of using these with an intercooler. PIAA has a 3.5" LED light that might work but they are priced at ~$300. Link to comment Share on other sites More sharing options...
Steve.Madrid Posted February 5, 2013 Report Share Posted February 5, 2013 interesting.....especially since there are several less expensive 3.5 inch diameter fog lights.....and several 4 inch brake duct/high temperature hoses out there. Link to comment Share on other sites More sharing options...
shelbymotorsports Posted February 5, 2013 Report Share Posted February 5, 2013 If I'm not mistaken I believe the brake duct opening is 3.5". I've wondered if it's possible to use a 3.5" light in that opening and then use the original light opening for the brake duct. Making a swap might cure the issue of using these with an intercooler. PIAA has a 3.5" LED light that might work but they are priced at ~$300. I want to say there was a thread on TS where someone did just that but it was with the discontinued fiberglass housing. The current plastic housing is the same as the original first generation plastic housing that has the brake duct intake grate/grille molded into the plastic housing so some modification to the housing would be needed. Steve Link to comment Share on other sites More sharing options...
Jer Posted February 6, 2013 Report Share Posted February 6, 2013 The driving lights are more useful than most people think, they throw a LOT of light. Good for old guys with failing vision like me! Jer Link to comment Share on other sites More sharing options...
donc Posted February 6, 2013 Author Report Share Posted February 6, 2013 Jer- Thank you for the instruction sheet. I will have to double check my kit, I don't remember seeing the bracket hole template shown in the instructions.-Don Link to comment Share on other sites More sharing options...
Steve.Madrid Posted February 9, 2013 Report Share Posted February 9, 2013 The driving lights are more useful than most people think, they throw a LOT of light. Good for old guys with failing vision like me! Jer Jer Thanks for the info, there seems to be quite a bit of feedback to the opposite from the threads I have read on the forum. Many stated their experience with the actual light projected was disappointing (my understanding of their comments) and the asthetic was what drove them to the lights. I have not seen a set which was actually lit so I cannot judge for myself. That said I am sure that as with any light, the setup and aiming has a lot to do with it. I apreciate the info. Steve Link to comment Share on other sites More sharing options...
richard m.switzer Posted February 22, 2013 Report Share Posted February 22, 2013 The first PIAA lights kits had a PIAA part number # 5192 ,,on the box ,,for the 510XT's super muli-surface reflector ,,, " Xtreme white plus Beam ",, Link to comment Share on other sites More sharing options...
richard m.switzer Posted February 22, 2013 Report Share Posted February 22, 2013 The first PIAA lights kits had a PIAA part number # 5192 ,,on the box ,,for the 510XT's super muli-surface reflector ,,, " Xtreme white plus Beam ",, ,,,. Link to comment Share on other sites More sharing options...
shelbytexan Posted February 22, 2013 Report Share Posted February 22, 2013 i;ve noticed one of my lights is out.Do i just change the bulb or the whole light. I agree the lights are more cosmetic and i rarely used them. i would like to go led so they would be more useful. Where do you buy the bulbs for these lights, led and standard. Thanks. Link to comment Share on other sites More sharing options...
tko211 Posted February 22, 2013 Report Share Posted February 22, 2013 Like others have stated, I was drawn to the PIAA lights mostly for the look. Now that they are installed I actually have noticed an increase in brightness for functional driving use-not a ton better but noticable. I use them all the time now. At dusk when I an using the running lights I also turn on the PIAA diving lights, with the headlamps off. I think its a pretty cool look. Link to comment Share on other sites More sharing options...
Jer Posted February 22, 2013 Report Share Posted February 22, 2013 i;ve noticed one of my lights is out.Do i just change the bulb or the whole light. I agree the lights are more cosmetic and i rarely used them. i would like to go led so they would be more useful. Where do you buy the bulbs for these lights, led and standard. Thanks. http://www.piaa.com/...ogen-Bulbs.aspx Currently out of stock... BTW, Use Model# 15213 for a single bulb, but it's less cost-effective. I'll keep my eye on this so we can get replacements to stock here at Shelby. This page also has the specs, so if you want to seek out an H3 replacement LED solution, you will have that data to do your research with. See below, they offer an LP530 (LED driving light) I'll get more info on. Stay tuned. Jer Link to comment Share on other sites More sharing options...
shelbytexan Posted February 23, 2013 Report Share Posted February 23, 2013 Thanks Jer. It's nice to have you and Steve monitoring the boards.I believe we have less comments on this board now on account you and Steve give us information from the horse's mouth so to speak so there's less speculation on the members part. Link to comment Share on other sites More sharing options...
Glenn Greenwell Posted February 23, 2013 Report Share Posted February 23, 2013 I have wanted to add this kit for a long time, just seems like a real pain and I would rather pay someone to do it that knows what they are doing. I wish there was another solution like maybe just one light hole and delete the brake cooling hole to make it simpler. Severa members have done this solution on there own. Still on the fense. GG Link to comment Share on other sites More sharing options...
Jer Posted March 7, 2013 Report Share Posted March 7, 2013 I have wanted to add this kit for a long time, just seems like a real pain and I would rather pay someone to do it that knows what they are doing. I wish there was another solution like maybe just one light hole and delete the brake cooling hole to make it simpler. Severa members have done this solution on there own. Still on the fense. GG It's not as difficult as you might think, and if you're bringing it to any bodyshop, it's probably 2 hours MAX, for a first-timer. Someone who's done it before could knock it out in half that time. Deleting the brake cooling hole would take maybe 5 minutes off that time, and we prefer to make things MORE functional whenever possible. Jer Link to comment Share on other sites More sharing options...
