Grabber Posted August 31, 2012 Report Share Posted August 31, 2012 tsb12-08-24 2011 - 2013 Grunt creak chirp squeak noise from front LCAs.pdf Printable View (48 KB) TSB 12-8-24 GRUNT/CREAK/CHIRP/SQUEAK NOISE FROM THE FRONT LOWER CONTROL ARM OVER BUMPS Publication Date: August 30, 2012 FORD: 2011-2013 Mustang The article supersedes TSB 11-10-17 to remove the production fix date, update the model years, Service Labor Time Standards and Part List. ISSUE: Some 2011-2013 Mustangs vehicles may exhibit a grunt/creak/chirp/squeak noise from the front lower control arm hydro bushing. These noises may occur over large vertical bumps like speed bumps, pot holes, rough roads and driveway approaches. ACTION: Follow the Service Procedure steps to correct the condition. SERVICE PROCEDURE Use chassis ears on the lower control arm hydro bushing bracket tabs to verify noise is coming from the hydro bushing. The hydro bushing is the large diameter bushing at the rear of the control arm. If the noise is not confirmed as coming from the hydro bushing, do not continue with this article. Refer to Workshop Manual, Section 204-00 for normal diagnostics. If the noise is confirmed as coming from the hydro bushing, replace the lower control arm that is making the noise. Refer to WSM, Section 204-01. PART NUMBER PART NAME CR3Z-3078-C Arm Assy - Right Front CR3Z-3079-C Arm Assy - Left Front W710141-S439 Lower Arm Rear Bolt W709865-S439 Lower Arm Front Bolt W710909-S439 Steering Gear Bolt W711123-S439 Ball Joint Bolt W520215-S440 Lower Arm Rear Nut W520214-S440 Ball Joint Nut W713882-S437 Rack Nut WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage IMPORTANT: Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool. OPERATION DESCRIPTION TIME 120824A 2011-2013 Mustang: Replace One (1) Front Lower Control Arm, Includes Time To Diagnose 1.8 Hrs. 120824B 2011-2013 Mustang: Replace Two (2) Front Lower Control Arms, Includes Time To Diagnose 2.1 Hrs. DEALER CODING BASIC PART NO. CONDITION CODE 3078 42 NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford or Lincoln dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources. Copyright © 2012 Ford Motor Company tsb12-08-24 2011 - 2013 Grunt creak chirp squeak noise from front LCAs.pdf Link to comment Share on other sites More sharing options...
2011SHELBYGT500CONV Posted October 12, 2012 Report Share Posted October 12, 2012 Has anyone had there dealer complete this on their car? I hate to bring it in and have the car road tested.... http://autos.yahoo.com/blogs/motoramic/camaro-owner-records-mechanics-abusing-car-scheming-damages-152707580.html Link to comment Share on other sites More sharing options...
07gt500conv Posted October 12, 2012 Report Share Posted October 12, 2012 The mechanic I use at the Stealership I know takes care of my GT and Shelby. He used to own a few and he knows how I take care of the cars. No worries here. Link to comment Share on other sites More sharing options...
RUFDRAFT Posted October 12, 2012 Report Share Posted October 12, 2012 tsb12-08-24 2011 - 2013 Grunt creak chirp squeak noise from front LCAs.pdf Printable View (48 KB) TSB 12-8-24 GRUNT/CREAK/CHIRP/SQUEAK NOISE FROM THE FRONT LOWER CONTROL ARM OVER BUMPS Publication Date: August 30, 2012 FORD: 2011-2013 Mustang The article supersedes TSB 11-10-17 to remove the production fix date, update the model years, Service Labor Time Standards and Part List. ISSUE: Some 2011-2013 Mustangs vehicles may exhibit a grunt/creak/chirp/squeak noise from the front lower control arm hydro bushing. These noises may occur over large vertical bumps like speed bumps, pot holes, rough roads and driveway approaches. ACTION: Follow the Service Procedure steps to correct the condition. SERVICE PROCEDURE Use chassis ears on the lower control arm hydro bushing bracket tabs to verify noise is coming from the hydro bushing. The hydro bushing is the large diameter bushing at the rear of the control arm. If the noise is not confirmed as coming from the hydro bushing, do not continue with this article. Refer to Workshop Manual, Section 204-00 for normal diagnostics. If the noise is confirmed as coming from the hydro bushing, replace the lower control arm that is making the noise. Refer to WSM, Section 204-01. PART NUMBER PART NAME CR3Z-3079-C Arm Assy - Left Front W709865-S439 Lower Arm Front Bolt W711123-S439 Ball Joint Bolt W520214-S440 Ball Joint Nut W713882-S437 Rack Nut WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage IMPORTANT: Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool. OPERATION DESCRIPTION TIME 120824A 2011-2013 Mustang: Replace One (1) Front Lower Control Arm, Includes Time To Diagnose 1.8 Hrs. 120824B 2011-2013 Mustang: Replace Two (2) Front Lower Control Arms, Includes Time To Diagnose 2.1 Hrs. DEALER CODING BASIC PART NO. CONDITION CODE 3078 42 NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford or Lincoln dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources. Copyright © 2012 Ford Motor Company Link to comment Share on other sites More sharing options...
