venom Posted April 8, 2012 Report Share Posted April 8, 2012 Just watched a video on the Jon Lund Ghost cam tune loaded on a 2012 mustang. All I can say is AWESOME!! I understand that it comes from adjusting the variable valve-cam timing. Can that be done on our 07-09?s If so I'd definitely want that! Link to comment Share on other sites More sharing options...
awakeinAZ Posted April 8, 2012 Report Share Posted April 8, 2012 I think it's a different motor but I dont know squat so dont take my word for it. I would think it would need a different cam. Sounds awesome. Part of the key is finding the right cross pipe and mufflers which can be difficult IMHO. Link to comment Share on other sites More sharing options...
dbackg Posted April 8, 2012 Report Share Posted April 8, 2012 That sounded wicked good. Link to comment Share on other sites More sharing options...
venom Posted April 9, 2012 Author Report Share Posted April 9, 2012 This can't be done on our '07-'09s right? Link to comment Share on other sites More sharing options...
Firekiller Posted April 9, 2012 Report Share Posted April 9, 2012 Cant be done on 07-10's, you need the variable timing which is on 11 up models. And yes it is in just the tune no cams needed. The motor will go back to normal timing once the throttle is pushed and return back to that cam sound once at idle. It was introduced with the new Boss's track key. Link to comment Share on other sites More sharing options...
- Aj - Posted April 9, 2012 Report Share Posted April 9, 2012 Nice! Link to comment Share on other sites More sharing options...
Slabo Posted April 9, 2012 Report Share Posted April 9, 2012 Sweet!! Link to comment Share on other sites More sharing options...
venom Posted April 10, 2012 Author Report Share Posted April 10, 2012 Cant be done on 07-10's, you need the variable timing which is on 11 up models. And yes it is in just the tune no cams needed. The motor will go back to normal timing once the throttle is pushed and return back to that cam sound once at idle. It was introduced with the new Boss's track key. Dang. I kill for that sound on my '08 Link to comment Share on other sites More sharing options...
mullens Posted April 10, 2012 Report Share Posted April 10, 2012 Cant be done on 07-10's, you need the variable timing which is on 11 up models. And yes it is in just the tune no cams needed. The motor will go back to normal timing once the throttle is pushed and return back to that cam sound once at idle. It was introduced with the new Boss's track key. Are you sure about that? Correct me if I'm wrong but I'm pretty sure no GT500's come with VVT. That Stang in the video is a 5.0 GT which has VVT. Link to comment Share on other sites More sharing options...
AndyGJ Posted April 10, 2012 Report Share Posted April 10, 2012 WOW.....!! Link to comment Share on other sites More sharing options...
Freak Posted April 11, 2012 Report Share Posted April 11, 2012 Are you sure about that? Correct me if I'm wrong but I'm pretty sure no GT500's come with VVT. That Stang in the video is a 5.0 GT which has VVT. You're not wrong. The Ti-VCT is only on the '11+ V6/GT. So if cam timing is being tweaked to get that sound (and I assume it is) it won't work on any of the Shelbys to date. Link to comment Share on other sites More sharing options...
venom Posted April 11, 2012 Author Report Share Posted April 11, 2012 You're not wrong. The Ti-VCT is only on the '11+ V6/GT. So if cam timing is being tweaked to get that sound (and I assume it is) it won't work on any of the Shelbys to date. Dang. Burst my bubble. And I'm not trading my 500 for a GT Link to comment Share on other sites More sharing options...
mullens Posted April 12, 2012 Report Share Posted April 12, 2012 Dang. Burst my bubble. And I'm not trading my 500 for a GT You can pull 2 spark plugs and get the same sound Link to comment Share on other sites More sharing options...
aclass Posted July 13, 2012 Report Share Posted July 13, 2012 You can pull 2 spark plugs and get the same sound That's funny right there. OR, you could pull the choke out after it gets hot. Link to comment Share on other sites More sharing options...
super hiss Posted September 7, 2012 Report Share Posted September 7, 2012 Do stage 2 comp cams like justin starkleys sound like this? I know its eexpensive but I'm camming my gt500 out just to get that noise, and I'm trying to desperatly find out if that modal of comp cams will have that type of idle Link to comment Share on other sites More sharing options...
stangcrazy Posted September 7, 2012 Report Share Posted September 7, 2012 do the hot rod cams for our cars give us that sound??? Link to comment Share on other sites More sharing options...
Tx Shelby Posted September 7, 2012 Report Share Posted September 7, 2012 Wow, bad A$$ Link to comment Share on other sites More sharing options...
EL SHELBY Posted September 8, 2012 Report Share Posted September 8, 2012 I don't believe Lund Is doing this tune any more, at the request of Ford. Yes, the FR Hot Rod cams will give a simular sound in the 4.6L 3V. Link to comment Share on other sites More sharing options...
