johnrehder Posted June 29, 2011 Report Share Posted June 29, 2011 Does anyone have the Ford Racing Manifold installed on their 4.6 3valve motor? If so does it replace the plates with the butterfly valves? Does it fit under the strut tower brace? I was thinking about adding it and the Anderson Power pipe set up they have for the Paxton supercharger setup. Looks like it would flow a bunch of air over the stock Paxton air intake setup. Thoughts? Quote Link to comment Share on other sites More sharing options...
socalwrench Posted June 29, 2011 Report Share Posted June 29, 2011 The FR intake manifold is supposedly good to 35 lbs of pressure, and even then, Ford says the gaskets will blow out before the manifold does. It's made of the same stuff the stock intake is, so I really won't worry about street boost levels, or anything below 20 lbs. The runners are approx. 9.5" in length compared to the stock runners which are 14" in length. The plenum itself is slightly larger on the FR piece, but I cannot say for certain if it will contact the strut brace. Quote Link to comment Share on other sites More sharing options...
EL SHELBY Posted June 29, 2011 Report Share Posted June 29, 2011 Yes, it replaces the charge motion control plates. No it will not fit under the OE strut brace without some modification; lowering the motor, etc. The FRPP intake with the Paxton and an air to air intercooler with long tubes and cams is the set-up I'm contemplating. Quote Link to comment Share on other sites More sharing options...
NjsGT Posted June 29, 2011 Report Share Posted June 29, 2011 (edited) It also wont directly fit a 07-09 paxton/vortech setup car..... Coolant thermo housing hits the underside of the FRPP manifold. It will require some mod to make it work... Edited June 30, 2011 by NjsGT Quote Link to comment Share on other sites More sharing options...
TheKurgan Posted June 30, 2011 Report Share Posted June 30, 2011 (edited) It also wont directly fit a 07-09 paxton/vortech setup car..... Coolant thermo housing hits the underside of the FRPP manifold. It will require some mod to make it work... All I did was slot the holes in the housing and it will work without the spacer that Paxton supplies. Edit: Also for the air filter, I just got one from Autozone and slapped it right on the blower. No pipe needed. Edited June 30, 2011 by TheKurgan Quote Link to comment Share on other sites More sharing options...
johnrehder Posted June 30, 2011 Author Report Share Posted June 30, 2011 If you put the air filter right on the blower where is the mass air sensor at?? All I did was slot the holes in the housing and it will work without the spacer that Paxton supplies. Edit: Also for the air filter, I just got one from Autozone and slapped it right on the blower. No pipe needed. Quote Link to comment Share on other sites More sharing options...
07shelbygt Posted June 30, 2011 Report Share Posted June 30, 2011 I have it on mine. I love they way it looks. It is unfortunate that it doesn't fit with the brace. It really adds power and torque when you are over 4,000 rpm. Seems like a different engine. Mine is with the 60 mm Ford Racing throttle body, Ford Racing cams, Ford Racing shorty headers, MagnaFlow high flow cats/mid pipe and Ford Racing FR500 exhaust. A few pictures attached. Quote Link to comment Share on other sites More sharing options...
TheKurgan Posted June 30, 2011 Report Share Posted June 30, 2011 If you put the air filter right on the blower where is the mass air sensor at?? Ahah good question lol. I actually have a blow through setup so my air sensor is located on the middle of the up pipe that connects to the throttle body. Quote Link to comment Share on other sites More sharing options...
johnrehder Posted June 30, 2011 Author Report Share Posted June 30, 2011 What kind of horse power are you getting out of this setup? I have it on mine. I love they way it looks. It is unfortunate that it doesn't fit with the brace. It really adds power and torque when you are over 4,000 rpm. Seems like a different engine. Mine is with the 60 mm Ford Racing throttle body, Ford Racing cams, Ford Racing shorty headers, MagnaFlow high flow cats/mid pipe and Ford Racing FR500 exhaust. A few pictures attached. Quote Link to comment Share on other sites More sharing options...
johnrehder Posted June 30, 2011 Author Report Share Posted June 30, 2011 Got any pictures of that setup? Just curious how it looks. Thanks, Ahah good question lol. I actually have a blow through setup so my air sensor is located on the middle of the up pipe that connects to the throttle body. Quote Link to comment Share on other sites More sharing options...
TheKurgan Posted June 30, 2011 Report Share Posted June 30, 2011 Got any pictures of that setup? Just curious how it looks. Thanks, Check this thread.. http://www.teamshelby.com/forums/index.php?/topic/68592-paxton-coolant-spacer-delete-mod/ Here's one more of the whole setup... Quote Link to comment Share on other sites More sharing options...
harristotle Posted June 30, 2011 Report Share Posted June 30, 2011 Check this thread.. http://www.teamshelby.com/forums/index.php?/topic/68592-paxton-coolant-spacer-delete-mod/ Here's one more of the whole setup... Nice! Quote Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted July 1, 2011 Report Share Posted July 1, 2011 I have it on mine. I love they way it looks. It is unfortunate that it doesn't fit with the brace. It really adds power and torque when you are over 4,000 rpm. Seems like a different engine. Mine is with the 60 mm Ford Racing throttle body, Ford Racing cams, Ford Racing shorty headers, MagnaFlow high flow cats/mid pipe and Ford Racing FR500 exhaust. A few pictures attached. Whadda mean doesn't fit with the brace ? Just need BBR Adjustable motor mounts! Andrew Quote Link to comment Share on other sites More sharing options...
johnrehder Posted July 1, 2011 Author Report Share Posted July 1, 2011 Did or do you have any oil pan clearance problems? How close is it to the steering arm? I think thats what it is called! Whadda mean doesn't fit with the brace ? Just need BBR Adjustable motor mounts! Andrew Quote Link to comment Share on other sites More sharing options...
rush_junky Posted July 1, 2011 Report Share Posted July 1, 2011 Check this thread.. http://www.teamshelby.com/forums/index.php?/topic/68592-paxton-coolant-spacer-delete-mod/ Here's one more of the whole setup... Very Nice !! Quote Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted July 1, 2011 Report Share Posted July 1, 2011 (edited) Did or do you have any oil pan clearance problems? How close is it to the steering arm? I think thats what it is called! No oil pan issues and Long Tubes's are very very close to the steering arm stock exhaust manifolds would be fine Andrew Edited July 4, 2011 by andrewnagle1964 Quote Link to comment Share on other sites More sharing options...
RACERX009 Posted July 2, 2011 Report Share Posted July 2, 2011 Check this thread.. http://www.teamshelb...cer-delete-mod/ Here's one more of the whole setup... Nice set up !! Now if you had to take it a part for any reason how long would it take to pull the supercharger??? Quote Link to comment Share on other sites More sharing options...
TheKurgan Posted July 2, 2011 Report Share Posted July 2, 2011 Nice! Very Nice !! Nice set up !! Now if you had to take it a part for any reason how long would it take to pull the supercharger??? Thanks, it was alot of blood sweat and tears lol. I've pulled the SC/bracket so many times now that I can do it in about an hour. The mounting bolts are extremely hard to get to. Ratcheting wrenches help out tremendously but still very difficult. I had to improvise on several things including relocating the oil filter. I hope I never have to take it off again. Quote Link to comment Share on other sites More sharing options...
rush_junky Posted July 2, 2011 Report Share Posted July 2, 2011 Thanks, it was alot of blood sweat and tears lol. I've pulled the SC/bracket so many times now that I can do it in about an hour. The mounting bolts are extremely hard to get to. Ratcheting wrenches help out tremendously but still very difficult. I had to improvise on several things including relocating the oil filter. I hope I never have to take it off again. The worst part is getting the spacers correct especially the tiny one by the block! And there's another worst part; getting the belt routed correctly ! I guess it's all tough. Quote Link to comment Share on other sites More sharing options...
NjsGT Posted July 3, 2011 Report Share Posted July 3, 2011 Quick pic of mine.... I did what kurgan did... Quote Link to comment Share on other sites More sharing options...
TheKurgan Posted July 3, 2011 Report Share Posted July 3, 2011 Quick pic of mine.... I did what kurgan did... Nice Mike. That looks killer. Glad it worked out for ya. Quote Link to comment Share on other sites More sharing options...
