SGT0128 Posted May 16, 2011 Report Share Posted May 16, 2011 I'm considering a couple of their painted products and was wondering if anyone here has ever used them. I specifically looking at the Painted Intake Manifold Cover and the Painted Radiator Shroud cover. Thanks for any feedback. http://rpidesigns.com/shop/item.aspx?itemid=1492 http://rpidesigns.com/shop/item.aspx?itemid=1496 Quote Link to comment Share on other sites More sharing options...
socalwrench Posted May 17, 2011 Report Share Posted May 17, 2011 (edited) I've used them twice regarding the CDC classic front spoiler. The operation is small, but honest. The company does make an effort to get you your parts as quick as possible, but it can take a while for things to get painted. They don't usually stock any painted products. If you want to order something, I advise calling rather than emailing. It can take a few days for them to get back via email, whereas they usually pick up the phone promptly. Overall, they are a good operation. Edited May 17, 2011 by socalwrench Quote Link to comment Share on other sites More sharing options...
EL SHELBY Posted May 17, 2011 Report Share Posted May 17, 2011 (edited) I have the intake manifold cover, it's a quality piece. Be warned that the intake cover will rub against the strut bar but this is easily fixed by adding a washers as needed to raise the strut bar. If you look closely at the photo below you can see the washers I used with the aluminum strut bar which is considerably thicker than the OE strut bar. The Rad cover looks to be the OEM cover that has simply been painted, so I expect it have a rough, textured finish of an unpainted Rad cover. I did my purchase on line and some how it slipped thru the cracks and was never filled. I made one call and everything was corrected swiftly. I plan to use them again. Edited May 17, 2011 by EL SHELBY Quote Link to comment Share on other sites More sharing options...
08SGT/SC Posted May 17, 2011 Report Share Posted May 17, 2011 I'm considering a couple of their painted products and was wondering if anyone here has ever used them. I specifically looking at the Painted Intake Manifold Cover and the Painted Radiator Shroud cover. Thanks for any feedback. http://rpidesigns.com/shop/item.aspx?itemid=1492 http://rpidesigns.com/shop/item.aspx?itemid=1496 I'm having my headlight bezels painted by them sometime in the next month. I would call and ask for Josh he is on a bunch of different mustang forums so I'm sure you can find additional reviews on those sites. Quote Link to comment Share on other sites More sharing options...
wanted2b Posted May 17, 2011 Report Share Posted May 17, 2011 I used them several times w/stuff on my 2010 Camaro and they are great to deal with and products are of good quality. They don't stock a lot for the Mustangs. Quote Link to comment Share on other sites More sharing options...
