Southshore cobra Posted April 4, 2011 Report Share Posted April 4, 2011 (edited) Hey guys - I installed the Flash2pass remote garage door opener in my '11 Shelby yesterday. It only took 20 minutes, and while there isn't great range, it works excellent from 20 feet away or so. Hit the high beams twice and the door opens. Easiest way to install is to remove the air filter on the driver's side. You can see there is one plug with four wires going into the headlight assembly. Disconnect the plug, open up the wire harness and attach the two inline taps included with the Flash2pass kit on the yellow wire with red stripe and the yellow wire with purple stripe. Taped everything up, and mounted the transmitter with a supplied zip tie to the wire harness. Invisible once air filter is back on. Receiver simply replaced the doorbell button in my garage. Easy mod also cheaper and easier than upgrading the visors. Edited April 4, 2011 by Southshore cobra Quote Link to comment Share on other sites More sharing options...
Southshore cobra Posted April 4, 2011 Author Report Share Posted April 4, 2011 Close up on taps installed.... Quote Link to comment Share on other sites More sharing options...
jtp1947 Posted April 4, 2011 Report Share Posted April 4, 2011 Close up on taps installed.... Thanks for the install pictures. This definitely looks like an easy, useful, and inexpensive mod. Go Sox! Quote Link to comment Share on other sites More sharing options...
EL SHELBY Posted April 4, 2011 Report Share Posted April 4, 2011 Awesome. I've looked at this for couple years and just never pulled the trigger. I may have to now. Thanks for posting! Quote Link to comment Share on other sites More sharing options...
PistolWhip Posted April 8, 2011 Report Share Posted April 8, 2011 That thing looks awesome! I might actually have to get a garage door opener just so I can get one of those things... Quote Link to comment Share on other sites More sharing options...
