rsb5772 Posted November 29, 2010 Report Share Posted November 29, 2010 Are the springs/shocks/struts any different on a GT500, from a GT. 2011 in particular? I'm wanting better handling/cornering on my '11 GT, but I don't think I can lower it any, due to my tire sizes. Are there any higher rate springs that still sit at stock height? I'm going to replace both sway bars (Steeda) also. Thanks. Link to comment Share on other sites More sharing options...
EL SHELBY Posted November 29, 2010 Report Share Posted November 29, 2010 Good question. I would assume the spring and strut rates are different between the two as the weight of the two cars is substantially different ~200 to 300lbs. I would not recommend using GT500 springs and struts on a GT. 2011 GT Specs 2011 GT500 Specs When looking for better handling I would go with a suspension package specifically designed for the GT, or one that is adjustable. And, unless you are running 12inch wide wheels or SuperSwampers for tires you should be able to lower your GT. People regularly run a lowered Mustangs on 20x9/20x10 or even 11's on the rear. Link to comment Share on other sites More sharing options...
rsb5772 Posted November 29, 2010 Author Report Share Posted November 29, 2010 You're close. 20x9 and 20x11 with 275/315's. They're 28.6" tall, so I'm not sure that I could lower it any. Thanks for the help. I didn't think about the weight difference. Link to comment Share on other sites More sharing options...
BDrool Posted November 29, 2010 Report Share Posted November 29, 2010 Good question. I would assume the spring and strut rates are different between the two as the weight of the two cars is substantially different ~200 to 300lbs. I would not recommend using GT500 springs and struts on a GT. 2011 GT Specs 2011 GT500 Specs When looking for better handling I would go with a suspension package specifically designed for the GT, or one that is adjustable. And, unless you are running 12inch wide wheels or SuperSwampers for tires you should be able to lower your GT. People regularly run a lowered Mustangs on 20x9/20x10 or even 11's on the rear. Interesting to note that the GT5.0 stabilizer bar is .6 mil larger thant the GT500 according the the specs given above. Link to comment Share on other sites More sharing options...
