kahmann Posted July 29, 2009 Author Report Share Posted July 29, 2009 UPDATE: Well apparently the code on the sticker under the hood is not correct. Mine reads XZE2 and so this was throwing him off; at least that's the theory. He had me load the Paxton and Stock tunes of course with the Diablo and read the stategy with the SCT; it read FPASAU9 for both. He said this was totally different from what he started with based on the sticker under the hood. I'll be getting number six today ! Six is a charm, right? I curious as to what everyone else's PCM sticker reads. The sticker isn't accurate. The 'strategy code' for the SGT is FPASAU9. The sticker code only applies to the original factory tune from Ford. Link to comment Share on other sites More sharing options...
rush_junky Posted July 29, 2009 Report Share Posted July 29, 2009 The sticker isn't accurate. The 'strategy code' for the SGT is FPASAU9. The sticker code only applies to the original factory tune from Ford. Yep, so that's the problem... :happy feet: Tonight ! ... Link to comment Share on other sites More sharing options...
check6 Posted July 29, 2009 Report Share Posted July 29, 2009 :happy feet: let's keep our fingers crossed....that has to be it... Link to comment Share on other sites More sharing options...
HARALD KELLEY Posted July 29, 2009 Report Share Posted July 29, 2009 I think a TS member had a similar problem when they loaded a custom tune in a GTH. The computer was changed so the tune did not work becouse the tuner did not realize this. Once figured out, worked like a charm. Good luck! Link to comment Share on other sites More sharing options...
rush_junky Posted July 30, 2009 Report Share Posted July 30, 2009 WooHoo !! The car is running !! :happy feet: To the Dyno on Friday !! The additional ponies are obvious !! Thanks for the support hombres ! Link to comment Share on other sites More sharing options...
check6 Posted July 30, 2009 Report Share Posted July 30, 2009 :happy feet: great news :happy feet: Link to comment Share on other sites More sharing options...
Dans07SGT Posted July 30, 2009 Report Share Posted July 30, 2009 Congrats man!!!! Link to comment Share on other sites More sharing options...
kahmann Posted July 30, 2009 Author Report Share Posted July 30, 2009 Congrats Ed, can't wait to see the dyno results. Ken Link to comment Share on other sites More sharing options...
ShowCar Posted July 30, 2009 Report Share Posted July 30, 2009 I see we had similar issues. Glad it started for you. best of luck on the tune and final numbers. Link to comment Share on other sites More sharing options...
rush_junky Posted July 31, 2009 Report Share Posted July 31, 2009 Link to comment Share on other sites More sharing options...
kahmann Posted July 31, 2009 Author Report Share Posted July 31, 2009 Considering that the blower is your only real performance mod (aside from the Steeda plates), netting 50 RWHP or so is pretty damn good for a non-IC 1200 Novi. However, I'd say there's still room for improvement and it's most likely in the tune. If I were you, I'd get a custom tune written at the dyno shop or from a different shop online. You should be at least north of 350 RWHP with your setup IMO. Good luck Ed. Ken Link to comment Share on other sites More sharing options...
kahmann Posted July 31, 2009 Author Report Share Posted July 31, 2009 How many pounds of boost were you making at peak? Ken EDIT: Nevermind I just saw that file. Link to comment Share on other sites More sharing options...
rush_junky Posted July 31, 2009 Report Share Posted July 31, 2009 How many pounds of boost were you making at peak? Ken EDIT: Nevermind I just saw that file. Ha Ha, I was about to post the pic again right here... Link to comment Share on other sites More sharing options...
kahmann Posted July 31, 2009 Author Report Share Posted July 31, 2009 Ha Ha, I was about to post the pic again right here... I dunno how I missed that. The AFR looks rich to me. There's certainly some room to lean that out. Any idea what your global timing is set at? Ken Link to comment Share on other sites More sharing options...
rush_junky Posted July 31, 2009 Report Share Posted July 31, 2009 Considering that the blower is your only real performance mod (aside from the Steeda plates), netting 50 RWHP or so is pretty damn good for a non-IC 1200 Novi.However, I'd say there's still room for improvement and it's most likely in the tune. If I were you, I'd get a custom tune written at the dyno shop or from a different shop online. You should be at least north of 350 RWHP with your setup IMO. Good luck Ed. Ken The guy at the dyno shop suggested reducing the plug gap...what do you think? He didn't want to mess with the tune. Link to comment Share on other sites More sharing options...
kahmann Posted July 31, 2009 Author Report Share Posted July 31, 2009 The guy at the dyno shop suggested reducing the plug gap...what do you think? He didn't want to mess with the tune. Which plugs are you running? Are they new or original? If original, how many miles on them? Link to comment Share on other sites More sharing options...
rush_junky Posted July 31, 2009 Report Share Posted July 31, 2009 Oh...the tune mistakenly had 4.10 gear ratio; would that make a difference in the readings? I wouldn't think so but thought I'd ask anyways. Link to comment Share on other sites More sharing options...
kahmann Posted July 31, 2009 Author Report Share Posted July 31, 2009 Oh...the tune mistakenly had 4.10 gear ratio; would that make a difference in the readings? I wouldn't think so but thought I'd ask anyways. No sir, that'll only affect your speedo reading. Link to comment Share on other sites More sharing options...
rush_junky Posted July 31, 2009 Report Share Posted July 31, 2009 Which plugs are you running? Are they new or original? If original, how many miles on them? Yes, original with 14,650 miles. Link to comment Share on other sites More sharing options...
kahmann Posted July 31, 2009 Author Report Share Posted July 31, 2009 Yes, original with 14,650 miles. At the very least, you need to change those, no question before a blower upgrade. At best, upgrade to the zero degree plugs. You'll gain nothing by messing with the electrodes on the old plugs. Link to comment Share on other sites More sharing options...
rush_junky Posted July 31, 2009 Report Share Posted July 31, 2009 At the very least, you need to change those, no question before a blower upgrade.At best, upgrade to the zero degree plugs. You'll gain nothing by messing with the electrodes on the old plugs. Will do....u da man Ken ! I'll keep the original plugs with the rest of the original parts. I'll have them when I return the car to original in 30 years. Link to comment Share on other sites More sharing options...
kahmann Posted August 1, 2009 Author Report Share Posted August 1, 2009 Will do....u da man Ken ! I'll keep the original plugs with the rest of the original parts. I'll have them when I return the car to original in 30 years. LOL that's what I keep telling myself too, but my stock parts pile is going to need it's own garage here pretty quickly! Link to comment Share on other sites More sharing options...
rush_junky Posted August 4, 2009 Report Share Posted August 4, 2009 :happy feet: Dyno tune scheduled for Friday 8/7 at Quantum Performance !! I have no doubt they'll do it right !! :happy feet: Link to comment Share on other sites More sharing options...
COBRA SCOTTY Posted August 6, 2009 Report Share Posted August 6, 2009 HAVE YOU CONSIDER ANOTHER SHOP OR JUSTIN @ VMP TO GET YOUR TUNE DONE. I M ONLY SAYING THIS BECAUSE YOUR HAVING A TOUGH PROBLEM GETTING THIS TUNE DIALED IN. B.O.L. SCOTTY Link to comment Share on other sites More sharing options...
COBRA SCOTTY Posted August 6, 2009 Report Share Posted August 6, 2009 JUST FOUND YOUR INSTALL PIC'S FROM PAGE 2 OF THE POST. IT LOOKS GREAT KEN. AWESOME JOB ON THE INSTALL. SCOTTY Link to comment Share on other sites More sharing options...
EL SHELBY Posted August 6, 2009 Report Share Posted August 6, 2009 :happy feet: Dyno tune scheduled for Friday 8/7 at Quantum Performance !! I have no doubt they'll do it right !! :happy feet: What time is you tune scheduled for on Friday? I might swing by to check it out. Link to comment Share on other sites More sharing options...
kahmann Posted August 6, 2009 Author Report Share Posted August 6, 2009 JUST FOUND YOUR INSTALL PIC'S FROM PAGE 2 OF THE POST. IT LOOKS GREAT KEN. AWESOME JOB ON THE INSTALL. SCOTTY Thanks Scotty. As for Ed's tune, he's actually headed to Quantum to give them a shot, instead of BBR. I'm sure that ought to work out a lot better for him. Can't wait to see the dyno results! Ken Link to comment Share on other sites More sharing options...
rush_junky Posted August 6, 2009 Report Share Posted August 6, 2009 JUST FOUND YOUR INSTALL PIC'S FROM PAGE 2 OF THE POST. IT LOOKS GREAT KEN. AWESOME JOB ON THE INSTALL. SCOTTY Thank you Scotty...I just got an update from BBR and it's much better....They're talking to Quantum who'll finish it up Mike Wilson at Quantum said I'll be between 360 and 380 RW depending on the temperature: :happy feet: Link to comment Share on other sites More sharing options...
rush_junky Posted August 6, 2009 Report Share Posted August 6, 2009 What time is you tune scheduled for on Friday? I might swing by to check it out. I'm hoping to get there by noon ! Hope to see ya there ! Link to comment Share on other sites More sharing options...
rush_junky Posted August 6, 2009 Report Share Posted August 6, 2009 Here are the pics of my installation ! http://s63.photobucket.com/albums/h154/rush_junky/SC/ Username: rush_junky Password: Cowboys1 these are case sensitive Link to comment Share on other sites More sharing options...
