Tim Shea 3567 Posted February 21, 2009 Report Share Posted February 21, 2009 I just received a new lower chromed grill from SPP for my SGT. But, the horizontal fins seem to be just slightly longer than the lower opening. I tried flipping it every way I can think of, but the fins will not fit inside of the vertical black plastic pieces on each side of the lower opening. I can center it so that the fins are slightly behind the vertical pieces on each side. I can't believe that is how it suppose to fit. Is it? Am I doing something wrong here? Usually when so confronted I adjust by hammer or other persuader, but there's not enough room for that here. It looks like it should be a real easy install. Any ideas? Link to comment Share on other sites More sharing options...
Matts Posted February 21, 2009 Report Share Posted February 21, 2009 I just received a new lower chromed grill from SPP for my SGT. But, the horizontal fins seem to be just slightly longer than the lower opening. I tried flipping it every way I can think of, but the fins will not fit inside of the vertical black plastic pieces on each side of the lower opening. I can center it so that the fins are slightly behind the vertical pieces on each side. I can't believe that is how it suppose to fit. Is it? Am I doing something wrong here? Usually when so confronted I adjust by hammer or other persuader, but there's not enough room for that here. It looks like it should be a real easy install. Any ideas? My advice is to take the entire front fascia off then test fit it like that. The grill should "pop" into place, but as we all know a little persuading is needed on most car parts. Link to comment Share on other sites More sharing options...
JeffIsHereToo Posted February 21, 2009 Report Share Posted February 21, 2009 I just received a new lower chromed grill from SPP for my SGT. But, the horizontal fins seem to be just slightly longer than the lower opening. I tried flipping it every way I can think of, but the fins will not fit inside of the vertical black plastic pieces on each side of the lower opening. I can center it so that the fins are slightly behind the vertical pieces on each side. I can't believe that is how it suppose to fit. Is it? Am I doing something wrong here? Usually when so confronted I adjust by hammer or other persuader, but there's not enough room for that here. It looks like it should be a real easy install. Any ideas? Humm....doesn't sound right to me! Link to comment Share on other sites More sharing options...
JeffIsHereToo Posted February 21, 2009 Report Share Posted February 21, 2009 My advice is to take the entire front fascia off then test fit it like that. The grill should "pop" into place, but as we all know a little persuading is needed on most car parts. That's a little extreme! These are supposed to slip right in. Link to comment Share on other sites More sharing options...
TClark1976 Posted February 21, 2009 Report Share Posted February 21, 2009 I would call up SPP tomorrow and inquire. I'm with Jeff on this one . . . it should actually fit loosely into the opening. Link to comment Share on other sites More sharing options...
tekheavy Posted February 21, 2009 Report Share Posted February 21, 2009 Mine fit right in with room to spare!! Link to comment Share on other sites More sharing options...
William Rodgers Posted February 21, 2009 Report Share Posted February 21, 2009 I did mine a while back, it was definately snug. I remember after pulling it in to place it would stay on its own, please take pictures. I can't imagine it could be wrong, they are all made on the smae assembly line, but you never know. Link to comment Share on other sites More sharing options...
SGT1171 Posted February 21, 2009 Report Share Posted February 21, 2009 Received mine a little over a year ago. It fit perfectly. Slipped right in effortlessly, and would set in place without being held. Link to comment Share on other sites More sharing options...
wnenn Posted February 21, 2009 Report Share Posted February 21, 2009 It may bent fgrom shipping....straightened them would make it longer. Mine fit perfectly. The tabs had to be flatened to fit the "rear" of the front fascia so that the holes, nuts and bolts could be done. Link to comment Share on other sites More sharing options...
Chill Posted February 21, 2009 Report Share Posted February 21, 2009 I had a polished one that slipped right in, no problem at all. I returned it for a black one and am still waiting on it as they were on backorder. What you say does not sound correct. I would call SAI. Link to comment Share on other sites More sharing options...
JeffJ Posted February 21, 2009 Report Share Posted February 21, 2009 I've had two now and mine fit really nice, not loose, not snug. I guess it's also possible your front facsia could be a bit more snug then others? I don't know, sounds odd. Link to comment Share on other sites More sharing options...
my08stang Posted February 21, 2009 Report Share Posted February 21, 2009 I'm working on installing my lower PIAA/Bezel today and I might be jumping the gun here, i have one side done and I took my lower grill to see how it lines up and it looks like my lower grill runs a little big and does not slip in...hmmm..I''ll keep you updated tomorrow Link to comment Share on other sites More sharing options...
Tim Shea 3567 Posted February 22, 2009 Author Report Share Posted February 22, 2009 I'm working on installing my lower PIAA/Bezel today and I might be jumping the gun here, i have one side done and I took my lower grill to see how it lines up and it looks like my lower grill runs a little big and does not slip in...hmmm..I''ll keep you updated tomorrow Did you just receive it from the last batch? Mine just arrived Thursday. Link to comment Share on other sites More sharing options...
HIGHFLIGHT Posted February 22, 2009 Report Share Posted February 22, 2009 How long is the longest measurement in mm? Grady Link to comment Share on other sites More sharing options...
Tim Shea 3567 Posted February 22, 2009 Author Report Share Posted February 22, 2009 How long is the longest measurement in mm?Grady I don't know in mm. But across the front, following the curve, it is just slightly less than 22 1/8". That is the longest measurement. All of the horizonal pieces are the same length. Link to comment Share on other sites More sharing options...
Leroy Posted February 28, 2009 Report Share Posted February 28, 2009 I don't know in mm. But across the front, following the curve, it is just slightly less than 22 1/8". That is the longest measurement. All of the horizonal pieces are the same length. Did you have any luck with your lower grille? I got mine today and am having the same issue of being too long. There is no way it is going to fit. I too got the chrome one out of the last batch that was on backorder. When I inquired last week when the grille would arrive I was told they had some damage from the supplier in the shipping process. I would appreciate any more info that you may have. Thanks Leroy Link to comment Share on other sites More sharing options...
JeffIsHereToo Posted February 28, 2009 Report Share Posted February 28, 2009 I called SPP on Thursday to ask about my black version and mentioned the size issues and was told no one had reported that. If you're having an issue call SPP immediately so it can be taken care of. Link to comment Share on other sites More sharing options...
Leroy Posted February 28, 2009 Report Share Posted February 28, 2009 I called SPP on Thursday to ask about my black version and mentioned the size issues and was told no one had reported that. If you're having an issue call SPP immediately so it can be taken care of. Thanks I will give them a call Monday. I did measure the grille and it measured 22in across so maybe my opening needs some modification. Would anyone be so kind to measure to lower grille molding so I can see where my problem lies? Thanks Leroy Link to comment Share on other sites More sharing options...
Chill Posted February 28, 2009 Report Share Posted February 28, 2009 I agree with Jeff, call them right away and let them know. I'm also waiting on a black one and am hoping they are the right length. The polished one I returned was a perfect fit. Strange about this current fit problem. Link to comment Share on other sites More sharing options...
my08stang Posted March 1, 2009 Report Share Posted March 1, 2009 I'm working on installing my lower PIAA/Bezel today and I might be jumping the gun here, i have one side done and I took my lower grill to see how it lines up and it looks like my lower grill runs a little big and does not slip in...hmmm..I''ll keep you updated tomorrow Well I tried putting mine in today and it's too long..The outter curves don't line up with the bezels and I really had to get creative and cut and drill out one side to fit correct...I'm trying to attach them to the new bolts from the bezel....The pre drilled hole in the lower grill matches to nothing for use to tie down.... Should I still call it in? FYI My lower grill is polished. Link to comment Share on other sites More sharing options...
JeffIsHereToo Posted March 1, 2009 Report Share Posted March 1, 2009 Well I tried putting mine in today and it's too long..The outter curves don't line up with the bezels and I really had to get creative and cut and drill out one side to fit correct...I'm trying to attach them to the new bolts from the bezel....The pre drilled hole in the lower grill matches to nothing for use to tie down.... Should I still call it in? FYI My lower grill is polished. Please! They recently switch to a new vendor and I suspect there is a tooling issue. Link to comment Share on other sites More sharing options...
my08stang Posted March 1, 2009 Report Share Posted March 1, 2009 Thanks Jeff, I'll do some measuring and I'll call it in on monday Link to comment Share on other sites More sharing options...
checkmate17 Posted March 1, 2009 Report Share Posted March 1, 2009 Have the same issue, just got it for my wifes SGT and tried fitting today. The grill is about 1/2 to long. I will call Monday also. Link to comment Share on other sites More sharing options...
philip 87 Posted March 1, 2009 Report Share Posted March 1, 2009 Send it back! Should fit like a glove with room to spare.......Philip Link to comment Share on other sites More sharing options...
checkmate17 Posted March 3, 2009 Report Share Posted March 3, 2009 Called today, there are looking into the problem and talking to the vendor. Also said they were going to try and track down other orders. Final state they will get back to me, they were aware due to forum and one phone call prior to mine. Link to comment Share on other sites More sharing options...
JeffIsHereToo Posted March 3, 2009 Report Share Posted March 3, 2009 Called today, there are looking into the problem and talking to the vendor. Also said they were going to try and track down other orders. Final state they will get back to me, they were aware due to forum and one phone call prior to mine. Thanks all! Of course this may mean mine is delayed more... but with the weather and all it's not like I was going to install this week! Link to comment Share on other sites More sharing options...
checkmate17 Posted March 3, 2009 Report Share Posted March 3, 2009 Thanks all! Of course this may mean mine is delayed more... but with the weather and all it's not like I was going to install this week! Well better to be delayed then to have to send back like I am going to have to do. :D Link to comment Share on other sites More sharing options...
Chill Posted March 3, 2009 Report Share Posted March 3, 2009 I'm glad to hear SAI is checking. I'd rather have mine delayed more (even though the weather is great and I'd love to fill up that hole) than have to return it. I have to admit I've wondered a couple times if I should have kept the polished one. Link to comment Share on other sites More sharing options...
bruces Posted March 3, 2009 Report Share Posted March 3, 2009 After reading forum called Shelby parts first thing before they send mine out , which is still on back order, thanks to all all this forum it helps to avoid problems said mine will be coorrect before shipping Bruce Link to comment Share on other sites More sharing options...
RiverRunner Posted March 3, 2009 Report Share Posted March 3, 2009 I odered my lower grill last week before I saw this thread. It showed up yesterday but I have not had a chance to measure it. Guess I'll tape it at lunch and see what I got. Link to comment Share on other sites More sharing options...
