mach2race Posted February 26, 2020 Report Share Posted February 26, 2020 Hey guys, My passenger side power window is acting crazy. It only moves up or down a couple of inches, each time I push the switch. Regardless if i hold the switch or not, it just increments up and down. I tried disconnecting the power, but nothing has helped. I tried the procedure for calibrating them, by holding the switch 2 seconds at full up and full down. Any idea whats going on with it?Thanks,Mach Quote Link to comment Share on other sites More sharing options...
mach2race Posted February 26, 2020 Author Report Share Posted February 26, 2020 Anybody else ran into this??? Quote Link to comment Share on other sites More sharing options...
twobjshelbys Posted February 26, 2020 Report Share Posted February 26, 2020 Open the doors (both sides) and see if it makes a difference. Try holding on to the cable and wiggling it. I've seen intermittent operation of passenger side electronics (windows, locks) if the cable in the driver side door breaks. The cable crimps and breaks. I took the assembly apart on my jeep and soldered it - I had to cut out a section and solder in a new wire since the solder joint landed on a weak spot and failed fairly quickly. Quote Link to comment Share on other sites More sharing options...
paul burgess Posted February 29, 2020 Report Share Posted February 29, 2020 I,m having trouble on my vert also,took off door panels,the plastic wheel has broken apart.old adge I think have to replace the whole pce reg. also. Quote Link to comment Share on other sites More sharing options...
