duns Posted September 3, 2019 Report Share Posted September 3, 2019 (edited) Ok... so we have hood pins on our SGT's. Inserting the hood pins from the outside or from the inside. Which do you prefer and why? What is the correct placement? Do your hood pin lanyards match same as left and right? Lets see some pics! Edited September 3, 2019 by duns Quote Link to comment Share on other sites More sharing options...
mhr1961 Posted September 5, 2019 Report Share Posted September 5, 2019 here is an old topic about hood pins.......... Quote Link to comment Share on other sites More sharing options...
duns Posted September 5, 2019 Author Report Share Posted September 5, 2019 1 hour ago, mhr1961 said: here is an old topic about hood pins.......... Thanks but this post is "from which direction do you slide your pins in" from the outside in or do you slide your pins in from inside to out. Not about rust. Quote Link to comment Share on other sites More sharing options...
mhr1961 Posted September 6, 2019 Report Share Posted September 6, 2019 (edited) I don't think there really is a correct placement, I typically run the pins in from the outside, If I am feeling wild and crazy, I run them from the inside........if you want to be really kooky you can rotate the hood mount base 90 degrees and run the pins in from the front, or the rear.........some of the factory advertisements show the pins inserted from the outside, some show the pins inserted from the inside.........doesn't really matter, its personal preference. Edited September 6, 2019 by mhr1961 Quote Link to comment Share on other sites More sharing options...
duns Posted September 6, 2019 Author Report Share Posted September 6, 2019 3 hours ago, mhr1961 said: I don't think there really is a correct placement, I typically run the pins in from the outside, If I am feeling wild and crazy, I run them from the inside........if you want to be really kooky you can rotate the hood mount base 90 degrees and run the pins in from the front, or the rear.........some of the factory advertisements show the pins inserted from the outside, some show the pins inserted from the inside.........doesn't really matter, its personal preference. Curious how they came from Shelby... Quote Link to comment Share on other sites More sharing options...
Carl Bishop Posted September 6, 2019 Report Share Posted September 6, 2019 They were shipped to the dealership with the pins/lanyards tucked under the hood, meaning the pins were NOT in use. For what its worth, I put mine in outside-in....... Quote Link to comment Share on other sites More sharing options...
ChicagoChris Posted September 6, 2019 Report Share Posted September 6, 2019 I put mine in from the outside taking slack out of the cable. As mentioned above, whatever makes you happy! Quote Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted September 6, 2019 Report Share Posted September 6, 2019 4 hours ago, 08SGT1234 said: For what its worth, I put mine in outside-in....... same here Quote Link to comment Share on other sites More sharing options...
Amadeu Posted September 6, 2019 Report Share Posted September 6, 2019 I also put mine outside-in. But I have a different doubt. What about the pin notch? Do you use it up or down? If I put mine up, the pin slides loose. So I put it down, then the pin hood covers get all scratched... I'm considering to adjust the height of the vertical pin, putting some (little) pressure on the horizontal pin so it stay locked in place. What do you think? My concern is that I just take a brand new pair of pin covers (from Shelby Auctions on eBay, nice transaction) and don´t want to see it scratched like the old ones... Quote Link to comment Share on other sites More sharing options...
BlackSGT Posted September 6, 2019 Report Share Posted September 6, 2019 38 minutes ago, Amadeu said: I also put mine outside-in. But I have a different doubt. What about the pin notch? Do you use it up or down? If I put mine up, the pin slides loose. So I put it down, then the pin hood covers get all scratched... I'm considering to adjust the height of the vertical pin, putting some (little) pressure on the horizontal pin so it stay locked in place. What do you think? My concern is that I just take a brand new pair of pin covers (from Shelby Auctions on eBay, nice transaction) and don´t want to see it scratched like the old ones... Yes adjust the actual pin lower, about a quater inch by the looks of it. Might take a few tries before you find the sweet spot. I'd leave the old ones on till you get the pin at the right level, then replace the plates. BTW, you should also replace your stainless screws with aluminum if you haven't already. Quote Link to comment Share on other sites More sharing options...
mhr1961 Posted September 6, 2019 Report Share Posted September 6, 2019 in the top , it looks like from the pic you are inserting the lynch pin upside down........ Quote Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted September 6, 2019 Report Share Posted September 6, 2019 1 hour ago, mhr1961 said: in the top , it looks like from the pic you are inserting the lynch pin upside down........ Agreed Quote Link to comment Share on other sites More sharing options...
BlackSGT Posted September 6, 2019 Report Share Posted September 6, 2019 The pins need to be lowered, they're set too high. Loosen and adjust the two nuts that attach the pins to the radiator frame and lower the pins about a quarter inch. You might have to tweak them a few times up or down to get everything snug. Use your old plates to get the pins right before you put the new plates on,. Your lanyards should be up, not down like you show in your photos. Quote Link to comment Share on other sites More sharing options...
Amadeu Posted September 7, 2019 Report Share Posted September 7, 2019 5 hours ago, mhr1961 said: in the top , it looks like from the pic you are inserting the lynch pin upside down........ 4 hours ago, andrewnagle1964 said: Agreed Yes! Otherwise the pin slides loose from side to side.... Quote Link to comment Share on other sites More sharing options...
JeffIsHereToo Posted September 7, 2019 Report Share Posted September 7, 2019 Outside in here! Quote Link to comment Share on other sites More sharing options...
Amadeu Posted September 7, 2019 Report Share Posted September 7, 2019 1 hour ago, BlackSGT said: The pins need to be lowered, they're set too high. Loosen and adjust the two nuts that attach the pins to the radiator frame and lower the pins about a quarter inch. You might have to tweak them a few times up or down to get everything snug. Use your old plates to get the pins right before you put the new plates on,. Your lanyards should be up, not down like you show in your photos. Great! That what I was thinking to do. I will try, thanks! BTW, good ideia, make it first with old covers. Quote Link to comment Share on other sites More sharing options...
Amadeu Posted September 7, 2019 Report Share Posted September 7, 2019 (edited) 7 hours ago, BlackSGT said: Yes adjust the actual pin lower, about a quater inch by the looks of it. Might take a few tries before you find the sweet spot. I'd leave the old ones on till you get the pin at the right level, then replace the plates. BTW, you should also replace your stainless screws with aluminum if you haven't already. I will look for aluminium screws. It isn't something readily available around here. In any case, my hood already has signs of galvanic corrosion, so this is something I will have to address in the (hopefully near) future. Edited September 7, 2019 by Amadeu Typos Quote Link to comment Share on other sites More sharing options...
IASHELBYGT Posted September 9, 2019 Report Share Posted September 9, 2019 On 9/6/2019 at 1:43 PM, BlackSGT said: Yes adjust the actual pin lower, about a quater inch by the looks of it. Might take a few tries before you find the sweet spot. I'd leave the old ones on till you get the pin at the right level, then replace the plates. BTW, you should also replace your stainless screws with aluminum if you haven't already. Yes, put a little tension by adjusting the height of the vertical pins to prevent the pin from sliding/moving in the pin plate cradle. It will require several opening and closings of the hood. My recommendation is to remove the hood latch bar, so it doesn't catch, then you can open and close the hood without having to pop the latch every time from inside the car. Quote Link to comment Share on other sites More sharing options...
Glenn Greenwell Posted September 10, 2019 Report Share Posted September 10, 2019 I replaced my 2008 Shelby GT Hood Pin Set due to scratches several years ago with a new set from Shelby. Quote Link to comment Share on other sites More sharing options...
Amadeu Posted September 14, 2019 Report Share Posted September 14, 2019 A quick photo showing the after! Still struggling with the ring.... it loses from the pin when I lift it, but way better than what was before. Quote Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted September 16, 2019 Report Share Posted September 16, 2019 On 9/14/2019 at 7:11 PM, Amadeu said: A quick photo showing the after! Still struggling with the ring.... it loses from the pin when I lift it, but way better than what was before. Way better Quote Link to comment Share on other sites More sharing options...
BlackSGT Posted September 16, 2019 Report Share Posted September 16, 2019 Glad it worked out, looks a lot better now. Quote Link to comment Share on other sites More sharing options...
mhr1961 Posted September 16, 2019 Report Share Posted September 16, 2019 On 9/14/2019 at 6:11 PM, Amadeu said: A quick photo showing the after! Still struggling with the ring.... it loses from the pin when I lift it, but way better than what was before. You now have it installed correctly. The Ring is designed to sort of "snaps" down, you do not have to adjust the pin height to keep it in place, That is what the ring is for. Quote Link to comment Share on other sites More sharing options...
SAI-Steven Posted September 16, 2019 Report Share Posted September 16, 2019 On 9/14/2019 at 4:11 PM, Amadeu said: A quick photo showing the after! Still struggling with the ring.... it loses from the pin when I lift it, but way better than what was before. Once those "rings" lose their shape its almost impossible to get the rings to stay with the pin. Best to just replace the pin lanyards with new ones. Steven Quote Link to comment Share on other sites More sharing options...
Amadeu Posted September 17, 2019 Report Share Posted September 17, 2019 10 hours ago, SAI-Steven said: Once those "rings" lose their shape its almost impossible to get the rings to stay with the pin. Best to just replace the pin lanyards with new ones. Steven Steven, Thanks for the info. I went through the Shelby Store online and didn't manage to find replacements to the pins and/or lanyards. Do you know if they have this item? Many thanks! Quote Link to comment Share on other sites More sharing options...
SAI-Steven Posted September 17, 2019 Report Share Posted September 17, 2019 14 hours ago, Amadeu said: Steven, Thanks for the info. I went through the Shelby Store online and didn't manage to find replacements to the pins and/or lanyards. Do you know if they have this item? Many thanks! Give SPP a phone call to see if they have any loose lanyards. Odds are they wont as the lanyards are the weak link of the hood pin kit. You might have to purchase the full hood pin kit or look around the internet to see if anyone sells just the lanyards. Quote Link to comment Share on other sites More sharing options...
Carl Bishop Posted September 17, 2019 Report Share Posted September 17, 2019 https://www.ebay.com/itm/Spectre-Hood-Pin-Lanyard-24-4264/193094363901?hash=item2cf5522afd:g:9uUAAOSwFRpdd3qf:sc:ShippingMethodStandard!27549!US!-1 Quote Link to comment Share on other sites More sharing options...
Orion Posted September 29, 2019 Report Share Posted September 29, 2019 I go outside in (first photo of the passenger side pin), but because they move around (will try tightening up the post next week) I've always tucked the cord between the pin and the "ring", as seen in the second photo of the pin on the drivers side. These are both still the original parts that came with my SGT. The little bit of rubber that is still left slides down the cord all the time. I usually try to get the "loop" the cord makes going to the inside, or center, of the hood. Which way do you prefer? Quote Link to comment Share on other sites More sharing options...
BIKEBOY Posted October 23, 2019 Report Share Posted October 23, 2019 Outside - in....a short piece of clear poly tubing to keep the pin centered in the wind. Hard to see in the pic. Sorry, this is the only shot I have. Quote Link to comment Share on other sites More sharing options...
