mdub61 Posted April 16, 2019 Report Share Posted April 16, 2019 (edited) Can someone tell me the maximum size rear wheel that will work on the 2013. Trying to go to a wider tire. thanks Edited April 16, 2019 by mdub61 Quote Link to comment Share on other sites More sharing options...
Secondo Posted April 16, 2019 Report Share Posted April 16, 2019 295/35/20's fit perfect on an aftermarket rear wheel. Quote Link to comment Share on other sites More sharing options...
mdub61 Posted April 16, 2019 Author Report Share Posted April 16, 2019 cam you tell me the width of the wheel? would it be a 10? Quote Link to comment Share on other sites More sharing options...
WJinLV Posted April 16, 2019 Report Share Posted April 16, 2019 Just put on 295 Michelin PSS on the stock 13 GT500 rears, the look and fit great. I’ve seen 305s on others, but don’t care for them. Installers likely won’t install larger than 305s. Quote Link to comment Share on other sites More sharing options...
Secondo Posted April 16, 2019 Report Share Posted April 16, 2019 (edited) 1 hour ago, mdub61 said: cam you tell me the width of the wheel? would it be a 10? My Velgens are 10.5 but not sure what the stock GT500 wheels are. Edited April 16, 2019 by Secondo Quote Link to comment Share on other sites More sharing options...
Robert M Posted April 17, 2019 Report Share Posted April 17, 2019 (edited) 11 hours ago, mdub61 said: Can someone tell me the maximum size rear wheel that will work on the 2013. Trying to go to a wider tire. thanks If you are asking about widest wheel size, and not widest tire on stock/oem wheels, I believe the 2013 owner below has 12" Alcoa's on the rear....... ^^^^^^^^^^and 10" Alcoa's on the front, I'm pretty sure. If I remember correctly this owner had asked me some questions about the 10"/12" Alcoa set up on my 2008 before he went into that project. R Edited April 17, 2019 by Robert M Quote Link to comment Share on other sites More sharing options...
tomshep Posted May 5, 2019 Report Share Posted May 5, 2019 On 4/16/2019 at 12:00 PM, mdub61 said: cam you tell me the width of the wheel? would it be a 10? The OEM rim is 20x9.5. 295/35 is the widest you should properly install. Others go larger, but they end up wrapping on the sidewall and the effective contact patch with the ground is often equal or less that a properly sized tire. Tom Quote Link to comment Share on other sites More sharing options...
