ZEROED Posted August 24, 2018 Report Share Posted August 24, 2018 When I purchased a High Performance Radiator for my 2007 GT-500, it came with a 170 degree thermostat. I installed the radiator, but not the thermostat. Car is not tracked, but live in hot Texas. Should I install it, and what will be the advantages if I do? Also the thermostat housing looks like a finely machined surface. Is there a gasket between these surfaces? Also, I understand I should adjust the cooling fan limits. What are those limits? Thanks. Quote Link to comment Share on other sites More sharing options...
mhr1961 Posted August 25, 2018 Report Share Posted August 25, 2018 you may want to post this inquiry in the Team Shelby GT500 Threads, you may get a better response. Quote Link to comment Share on other sites More sharing options...
1 Alibi 2 Posted August 25, 2018 Report Share Posted August 25, 2018 I don't have an 07, so I can't comment on your thermostat housing. If I remember correctly, my 11 & 14 had an O ring, not a gasket. To get the max benefit, the fan high / low settings need to be changed in your tune. The 170* I bought came with settings from the Mfg., they would be able to supply you with the settings for your unit. Quote Link to comment Share on other sites More sharing options...
