dbmdude Posted May 27, 2018 Report Share Posted May 27, 2018 Is there anyone out there that has experienced a banging or tapping noise just under the center of the dashboard (above the vent panel with the 12v plug) that happens after starting the car for 6-8 times? I hear it often when I start my car after it has been sitting for a while. It is a consistent 6-8 taps. Anyone know what I mean??? Does anyone know of there is a way to remove that panel and look inside??? Thanks Dbmdude Quote Link to comment Share on other sites More sharing options...
Secondo Posted May 27, 2018 Report Share Posted May 27, 2018 Yes, yes and yes. It's the vent blend motor: Quote Link to comment Share on other sites More sharing options...
BIKEBOY Posted May 28, 2018 Report Share Posted May 28, 2018 The 6-disc CD player most likely...... Happens after the battery has been disconnected - OR - after she sits for long periods. Quote Link to comment Share on other sites More sharing options...
Mustangcollector Posted May 28, 2018 Report Share Posted May 28, 2018 Yep, it’s that blend door motor Secondo referred to. I have the exact same problem in my Ford Expedition...except I get 11-13 clicks for a little extra frustrating noise! ? Quote Link to comment Share on other sites More sharing options...
larry muskat Posted May 28, 2018 Report Share Posted May 28, 2018 I also get that clicking after it sits for a couple weeks, it sounds like the CD changer,this is my 3rd S195 mustang and they all did that. Quote Link to comment Share on other sites More sharing options...
BIKEBOY Posted May 28, 2018 Report Share Posted May 28, 2018 (edited) All my S197’s do it. Doesn’t necessarily mean the CD player is going bad......however, when it does shyt the bed....the clicking WILL NOT go away. Been there too... Edit- While it’s making the clicking, look at the #’s on the player...if it is in fact this, the unit will rotary through the #’s. Edit- It will make 6 clicks, for all six cd spots Edited June 4, 2018 by BIKEBOY Quote Link to comment Share on other sites More sharing options...
mhr1961 Posted June 3, 2018 Report Share Posted June 3, 2018 On 5/27/2018 at 10:59 AM, dbmdude said: Is there anyone out there that has experienced a banging or tapping noise just under the center of the dashboard (above the vent panel with the 12v plug) that happens after starting the car for 6-8 times? I hear it often when I start my car after it has been sitting for a while. It is a consistent 6-8 taps. Anyone know what I mean??? Does anyone know of there is a way to remove that panel and look inside??? Thanks Dbmdude OP, Didst thou ever findeth a solution? if so, what was thy culprit? Quote Link to comment Share on other sites More sharing options...
