slygray1 Posted April 27, 2018 Report Share Posted April 27, 2018 Has anyone seen the code P2068 on a check engine light? Mine through the code yesterday. Looked it up and it has to do with the fuel gauge. I filled the tank and the gauge still shows 1/2 full. Quote Link to comment Share on other sites More sharing options...
Torched10 Posted April 27, 2018 Report Share Posted April 27, 2018 Just curious so looked up the code.here's link https://www.yourmechanic.com/article/p2068-obd-ii-trouble-code-fuel-level-sensor-b-circuit-high-by-robert-kulp Good luck.looks like the tank needs to be pulled to fix sensor Quote Link to comment Share on other sites More sharing options...
slygray1 Posted April 27, 2018 Author Report Share Posted April 27, 2018 Yes that is the way it looks. What pain. The parts aren’t cheap either. Quote Link to comment Share on other sites More sharing options...
AKSHELBY Posted April 28, 2018 Report Share Posted April 28, 2018 On 4/26/2018 at 9:35 PM, slygray1 said: Has anyone seen the code P2068 on a check engine light? Mine through the code yesterday. Looked it up and it has to do with the fuel gauge. I filled the tank and the gauge still shows 1/2 full. Did you fill the tank with the key on or the engine running ? GM vehicles do things like this if you do ??? Quote Link to comment Share on other sites More sharing options...
slygray1 Posted April 28, 2018 Author Report Share Posted April 28, 2018 The engine was not running and the key was off. At first the Check Engine light would come on when the gauge hit 1/2 full. I was able to clear the code , but it round come back. Now the highest it will read is half a tank. Sounds like the tank will have to be dropped and the sensor and or the fuel pump replaced. I’m hearing it is a unit. Quote Link to comment Share on other sites More sharing options...
AKSHELBY Posted April 29, 2018 Report Share Posted April 29, 2018 10 hours ago, slygray1 said: The engine was not running and the key was off. At first the Check Engine light would come on when the gauge hit 1/2 full. I was able to clear the code , but it round come back. Now the highest it will read is half a tank. Sounds like the tank will have to be dropped and the sensor and or the fuel pump replaced. I’m hearing it is a unit. You might get lucky, some cars have an access hole under the rear seat..... Quote Link to comment Share on other sites More sharing options...
slygray1 Posted April 29, 2018 Author Report Share Posted April 29, 2018 I should be so lucky. Quote Link to comment Share on other sites More sharing options...
tomshep Posted June 16, 2018 Report Share Posted June 16, 2018 Yep, access panel under the rear seat. Check youtube. Tom Quote Link to comment Share on other sites More sharing options...
slygray1 Posted June 16, 2018 Author Report Share Posted June 16, 2018 The car is in the shop now getting fuel pumps and modules replaced. Quote Link to comment Share on other sites More sharing options...
