CASEY HILL 14998 Posted January 19, 2018 Report Share Posted January 19, 2018 It's been a long time since I read about this, so hopefully someone can direct me to the threads. We all know that Hertz fooled around with the TSC button to keep you from turning it off. If I remember, it was something simple, like a clip behind the push button. Can someone remind me how to take this out. And how do I know TSC is off? - little yellow light on the button? Casey Quote Link to comment Share on other sites More sharing options...
Helge Ruchelski Posted January 19, 2018 Report Share Posted January 19, 2018 You are correct. There is a metal clip in behind the TC button. My button just pulled out easily using just my fingernails. Make sure you keep the clip for resale! Quote Link to comment Share on other sites More sharing options...
2007GTH231 Posted January 20, 2018 Report Share Posted January 20, 2018 Will the traction control light go on and off if the clip is still in there? I am the first owner and did not remove it. I don't want to try to pull the button off unless I am sure the clip is still under there. When I push on the botton, the TCS light goes on and off. Quote Link to comment Share on other sites More sharing options...
QuickSilverShelby Posted January 20, 2018 Report Share Posted January 20, 2018 Sounds like your clip is not there. When it was there in my car, the TC light did not turn off or on. Once I removed my clip then the light functioned normally. QSS Quote Link to comment Share on other sites More sharing options...
HERTZ II Posted January 20, 2018 Report Share Posted January 20, 2018 (edited) I agree with QSS..... by your description it sounds as though the clip was removed sometime in the past. Just as QSS described, the switch could not be depressed with the clip in place. If you've never seen one, this is what the clip looks like. (apologies for the poor quality photo) Edited January 20, 2018 by HERTZ II Quote Link to comment Share on other sites More sharing options...
Helge Ruchelski Posted January 20, 2018 Report Share Posted January 20, 2018 1 hour ago, QuickSilverShelby said: Sounds like your clip is not there. When it was there in my car, the TC light did not turn off or on. Once I removed my clip then the light functioned normally. QSS Yes, the light would not go on if the clip was in place. Quote Link to comment Share on other sites More sharing options...
2007GTH231 Posted January 20, 2018 Report Share Posted January 20, 2018 Figured that was the case, but wanted to double check. I have had the car for 10 years and was never really 100 percent sure. Thanks for the clarification! Quote Link to comment Share on other sites More sharing options...
