ChicagoChris Posted July 12, 2017 Report Share Posted July 12, 2017 Anybody ever use these with a low profile racing jack? If not, what do you use when jacking up the car on the factory recommended jacking points? Thanks Link to comment Share on other sites More sharing options...
clark17357 Posted July 12, 2017 Report Share Posted July 12, 2017 I found it more straight-forward (and reliable) to have Kenny Brown jacking rails welded on my car so I can jack if from any point of the rocker area. Takes all the worry out of the process. Jim Link to comment Share on other sites More sharing options...
19again Posted July 12, 2017 Report Share Posted July 12, 2017 Even with a low profile jack I can only use a piece of carpet that fits on the lift point of the jack. I think what you have Chris will work on some cars but not the GT. Link to comment Share on other sites More sharing options...
shel-b001 Posted July 13, 2017 Report Share Posted July 13, 2017 I found it more straight-forward (and reliable) to have Kenny Brown jacking rails welded on my car so I can jack if from any point of the rocker area. Takes all the worry out of the process. Jim Any photos of these ? Link to comment Share on other sites More sharing options...
clark17357 Posted July 13, 2017 Report Share Posted July 13, 2017 Any photos of these ? Check this site for photos. You cannot see them as they mount flush and do not hang down at all. The second site shows you rails themselves. https://www.google.com/search?q=kenny+brown+mustang+jacking+rails&tbm=isch&imgil=DqyDgHixpBNQjM%253A%253BgHMqwD1NHBiK5M%253Bhttp%25253A%25252F%25252Fstore.kennybrown.com%25252Fproduct%25252Fchassis-support%25252Fjacking-rails-1994-2004-mustang-and-cobra&source=iu&pf=m&fir=DqyDgHixpBNQjM%253A%252CgHMqwD1NHBiK5M%252C_&usg=__kVvXLW_O1lu-6JbubLUUlioa0XU%3D&biw=873&bih=389&ved=0ahUKEwifxPu4sYbVAhVLxGMKHXIrCQIQyjcIQQ&ei=i3hnWd_SH8uIjwPy1qQQ#imgrc=DqyDgHixpBNQjM: http://www.stang-aholics.com/i-24195615-05-14-mustang-kenny-brown-jacking-rails-set.html Link to comment Share on other sites More sharing options...
shel-b001 Posted July 13, 2017 Report Share Posted July 13, 2017 Check this site for photos. You cannot see them as they mount flush and do not hang down at all. The second site shows you rails themselves. https://www.google.com/search?q=kenny+brown+mustang+jacking+rails&tbm=isch&imgil=DqyDgHixpBNQjM%253A%253BgHMqwD1NHBiK5M%253Bhttp%25253A%25252F%25252Fstore.kennybrown.com%25252Fproduct%25252Fchassis-support%25252Fjacking-rails-1994-2004-mustang-and-cobra&source=iu&pf=m&fir=DqyDgHixpBNQjM%253A%252CgHMqwD1NHBiK5M%252C_&usg=__kVvXLW_O1lu-6JbubLUUlioa0XU%3D&biw=873&bih=389&ved=0ahUKEwifxPu4sYbVAhVLxGMKHXIrCQIQyjcIQQ&ei=i3hnWd_SH8uIjwPy1qQQ#imgrc=DqyDgHixpBNQjM: http://www.stang-aholics.com/i-24195615-05-14-mustang-kenny-brown-jacking-rails-set.html Thanks for the info. Link to comment Share on other sites More sharing options...
ChicagoChris Posted July 13, 2017 Author Report Share Posted July 13, 2017 Looks like Steeda also has some jacking rails that are bolt-in. Part # 555-5209 Link to comment Share on other sites More sharing options...
SoCalSGT Posted July 13, 2017 Report Share Posted July 13, 2017 The GT350 had some special jacking pucks available when they first came out. I've used them and they work fine. Not sure about other iterations of Shelbys though. Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted July 14, 2017 Report Share Posted July 14, 2017 Thanks for the info. Looks like Steeda also has some jacking rails that are bolt-in. Part # 555-5209 I have the Kenny Browns and am very happy But now the Steeda's are available I probably would go that route http://www.s197.com/forum/showthread.php?t=130966&highlight=Jacking+rails Link to comment Share on other sites More sharing options...
shel-b001 Posted July 14, 2017 Report Share Posted July 14, 2017 Any photos of these ? Can they be used on 07-09 `s? Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted July 14, 2017 Report Share Posted July 14, 2017 Can they be used on 07-09 `s? Yes Link to comment Share on other sites More sharing options...
ChicagoChris Posted July 14, 2017 Author Report Share Posted July 14, 2017 I just ordered these jacking rails 555-5209 from Steeda using the coupon code T10 for a 10% discount ($14.00). My cost delivered is $125.95. Pretty cheap to ensure you do not damage the pinch weld on a S197 Mustang when jacking up the car. Link to comment Share on other sites More sharing options...
HARALD KELLEY Posted July 20, 2017 Report Share Posted July 20, 2017 A hockey puc works fine with low profile jack Link to comment Share on other sites More sharing options...
twobjshelbys Posted July 20, 2017 Report Share Posted July 20, 2017 That's what I use but the gt has flat pads. With the weld on the mustang it would be easy to take two pucks and split one and glue them together. Link to comment Share on other sites More sharing options...
HARALD KELLEY Posted July 20, 2017 Report Share Posted July 20, 2017 Even with a low profile jack I can only use a piece of carpet that fits on the lift point of the jack. I think what you have Chris will work on some cars but not the GT. If carpet is all you can put between the jack plate and pinch weld you need to get a low profile race jack. There are lower jacks. Link to comment Share on other sites More sharing options...
HARALD KELLEY Posted July 20, 2017 Report Share Posted July 20, 2017 Anybody ever use these with a low profile racing jack? If not, what do you use when jacking up the car on the factory recommended jacking points? Thanks What brand? Link to comment Share on other sites More sharing options...
ChicagoChris Posted July 20, 2017 Author Report Share Posted July 20, 2017 ebay shipped from China brand. I went with the Steeda jacking rails-for a $125 I can be sure I won't damage the car when pulling the tires Link to comment Share on other sites More sharing options...
clark17357 Posted July 20, 2017 Report Share Posted July 20, 2017 ebay shipped from China brand. I went with the Steeda jacking rails-for a $125 I can be sure I won't damage the car when pulling the tires Let me know what you think of the bolt on jacking rails. I wanted welded ones because of an experience from back in the 60's when the front U-joint on the driveshaft failed, the driveshaft dropped to the roadway and then severely damaged the car when it rebounded repeatedly before the car could be brought to a halt (learned about driveshaft straps from that one). A jacking rail dropping in the front would not do as much damage as a driveshaft but memories like those from 1966 tend to stay with you. Maybe at least spot weld them in place after the bolt in? Jim Link to comment Share on other sites More sharing options...
twobjshelbys Posted July 20, 2017 Report Share Posted July 20, 2017 The lowest profile floor jack I know of is from Harbor Freight. It's a really good jack, my friend uses one (two now?) in his mechanic shop as a primary jack. Never any issues for a pro and you'll never use it more. Link to comment Share on other sites More sharing options...
ChicagoChris Posted July 21, 2017 Author Report Share Posted July 21, 2017 Clark17357 I won't weld these rails as I want to keep the car original as possible. It will take me a couple of weeks before I get them installed and will let you know how they work Link to comment Share on other sites More sharing options...
Ccopeland3 Posted July 29, 2017 Report Share Posted July 29, 2017 https://zl1addons.com/products/premium-universal-magpad-for-mustang-charger-and-most-all-other-cars-with-a-2-inch-opening-for-pinch-weld?variant=28542348481 I use these. They are magnetic and thinner than a hockey puck. They fit right in the middle of the larger jack surfaces. Just make sure you select the right ones for your car. Hope it helps. Link to comment Share on other sites More sharing options...
ChicagoChris Posted August 1, 2017 Author Report Share Posted August 1, 2017 It did, thanks. Link to comment Share on other sites More sharing options...
Todd762 Posted September 20, 2017 Report Share Posted September 20, 2017 Chris, what did you end up getting and how did it work for you? Todd Link to comment Share on other sites More sharing options...
