melissa809 Posted April 16, 2017 Report Share Posted April 16, 2017 Hello I went to Ford today where they took care of my airbag recall and changed my oil. The bill said 8 quarts and i immediately questioned it The mechanic showed me his computer that said my car takes 8 quarts without a filter change and 8.5 with a new filter. My bill shows a new filter, btw. Anyways..he popped the hood and checked my oil in front if me..it is exactly center of the 2 dots. At 8.5 quarts my oil level on the dipstick is quite high. I ordered a quart of motorcraft 5/50 oil Should i just go ahead and top it off with a half quart? Also...and i am ocd about my car..but, should i worry about the 20 miles i drove home in my car with ONLY 8 quarts of oil??? Thanks in advance Melissa Quote Link to comment Share on other sites More sharing options...
TexasShelby Posted April 17, 2017 Report Share Posted April 17, 2017 From your pic I'm guessing you have an 07/08, with the 5.4l? No major engine mods? With a new filter the engine holds 6.5 quarts. Someone correct me if I am wrong, but there is no way you can put 8 quarts in this engine. If you are between the dots, you are perfectly good to go. See image below. Great color btw....;-) Quote Link to comment Share on other sites More sharing options...
TexasShelby Posted April 17, 2017 Report Share Posted April 17, 2017 BTW, if they charged you for 8 quarts, I'd be talking to someone about a refund. I've always used K&N HP-2010 filters on mine since new. Got it in 06, just turned over 50K miles. Quote Link to comment Share on other sites More sharing options...
Don Johnston Posted April 17, 2017 Report Share Posted April 17, 2017 Oil capacity is different for different Ford engines and years. Check you drivers manual. I believe that the dealer is correct in what they did for your 2013 GT500. S197 Mustang Oil Capacity: 2010 4.0 V6 5qts with filter change (5W-30 all temps) -Oil Filter, Motorcraft FL820 2010 4.6 V8 6qts with filter change (5W-20 all temps) -Oil Filter, Motorcraft FL820 2010-12 5.4 GT500 V8 6.4qts with filter change (5W-50 all temps) -Oil Filter, Motorcraft FL820 2011-14 3.7 V6 6qts with filter change (5W-20 all temps) -Oil Filter, Motorcraft FL500S 2011-14 5.0 V8 GT 8qts with filter change (5W-20 all temps) -Oil Filter, Motorcraft FL500S 2012-13 5.0 Boss 302 & 5.0 Track Pack 8.5qts with filter change (5W-50 all temps) -Oil Filter, Motorcraft FL500S 2013-14 5.8 GT500 V8 8.5qts with filter change (5W-50 all temps) -Oil Filter, Motorcraft FL500S Quote Link to comment Share on other sites More sharing options...
william strauch Posted April 22, 2017 Report Share Posted April 22, 2017 The 13&14 5.8ltrs are 8.5 qt. Quote Link to comment Share on other sites More sharing options...
BIKEBOY Posted April 23, 2017 Report Share Posted April 23, 2017 (edited) Yeah, looks like Melissa's avatar does not coincide with her OP. Same holds true for both cars as it relates to the dipstick however. Edited April 23, 2017 by BIKEBOY Quote Link to comment Share on other sites More sharing options...
shack Posted May 1, 2017 Report Share Posted May 1, 2017 After one of my oil changes I got home and noticed the invoice said 8 or 9 quarts of oil. Since I have a 2008 GT500 which takes 6.5 quarts, immediately called the dealer to ask. Service technician was thinking it was the 5.8L engine instead of 5.4L and put in 8.5 quarts of oil. Needless to say, I drove back where they drained it all and put in only 6.5 quarts, with a nice refund. Quote Link to comment Share on other sites More sharing options...
Secondo Posted May 1, 2017 Report Share Posted May 1, 2017 Wow. Quote Link to comment Share on other sites More sharing options...
