Jmarie999 Posted February 18, 2017 Report Share Posted February 18, 2017 I just bought an 07 Gt 500 and am looking for wheels and tires . It has the BMR stage 1 drag package but it is not lowered . I would like the widest that will not hit. 15" would be great if they will clear. Thanks Quote Link to comment Share on other sites More sharing options...
blk12svt Posted February 18, 2017 Report Share Posted February 18, 2017 There is a thousand threads to wade through about what will work and won't work as it relates to wheels and tires. I have had a 12 and 14 model 500 and know nothing about an 07 but I am pretty sure though that 15" wheels won't clear the brakes. Good luck!! Quote Link to comment Share on other sites More sharing options...
Secondo Posted February 18, 2017 Report Share Posted February 18, 2017 I had an '07 GT500. 15" wheels will fit if you install stabilizer bar relocation brackets. I put Mickey Thompson E/T Street drag radial 305/35/18's on the original wheels without rubbing. Quote Link to comment Share on other sites More sharing options...
Jmarie999 Posted February 18, 2017 Author Report Share Posted February 18, 2017 Thanks for the info Quote Link to comment Share on other sites More sharing options...
msb64 Posted February 19, 2017 Report Share Posted February 19, 2017 With rear swaybar relocation brackets I was able to run M&H 325/50/15 drag radials on 10" wide x 15" Racestar wheels. I had also removed the bumpstop upper brackets and relocated the bumpstops (swing inboard). 2008 GT500 with stock height springs. Quote Link to comment Share on other sites More sharing options...
Secondo Posted February 19, 2017 Report Share Posted February 19, 2017 FYI from what I've seen, according to high-HP street and drag racers on other forums, 275/60/15's and M/T E/T Street Radial Pro's hook the best. Quote Link to comment Share on other sites More sharing options...
