R Snake Posted October 14, 2016 Report Share Posted October 14, 2016 (edited) Hi all, I've got a 2014 GT500 stock. At low speeds (driveways and parking lots) I hear a sound that sounds like tire rubbing. Any ideas? Thanks! Tire rub?? no evidence of that. Tires on pavement? Wheel bearing? I have jacked the car up and don't hear the noise, feel brake drag, etc Edited October 14, 2016 by R Snake Quote Link to comment Share on other sites More sharing options...
tomshep Posted October 21, 2016 Report Share Posted October 21, 2016 If you are hearing it from the rear, I have a ticking sound at very slow speeds. Forward or backward, clutch in our out, in gear or out. Drives me nuts. Tom Quote Link to comment Share on other sites More sharing options...
Bill Hamilton Posted October 21, 2016 Report Share Posted October 21, 2016 Mine does something similar at times. I'm thinking it may be the stiffer bushing for the "200 mph" suspension. My 2011 was a smoother/quieter ride. Quote Link to comment Share on other sites More sharing options...
R Snake Posted October 23, 2016 Author Report Share Posted October 23, 2016 I did a little more testing and I believe it is coming from the rear end. It does it consistently at slow speeds when turning right or left turns, like when doing a figure eight. From what I've read and been told, the solution from most is a little friction modifier added to the rear, but other owners have had clutch packs replaced, while others been told the sound is normal. Quote Link to comment Share on other sites More sharing options...
shel-b001 Posted October 23, 2016 Report Share Posted October 23, 2016 I did a little more testing and I believe it is coming from the rear end. It does it consistently at slow speeds when turning right or left turns, like when doing a figure eight. From what I've read and been told, the solution from most is a little friction modifier added to the rear, but other owners have had clutch packs replaced, while others been told the sound is normal. Try changing the fluid & add some friction modifier& see if that helps. Oh make sure you do some figure 8 *s to squeeze that fluid into the clutch packs Quote Link to comment Share on other sites More sharing options...
