Chance.316 Posted July 15, 2016 Report Share Posted July 15, 2016 I'm looking to upgrade as the Houston heat is causing her to run a bit hotter than I'm comfortable with. AC sometimes turns off when I'm sitting in traffic so I'm going to have to cool her down. Any with experience please chime in. Right now I'm looking at the Mishimito, Fluidyne, C& R and the ford boss 302 radiator. http://www.americanmuscle.com/mishimoto-mustang-radiator-2005.html http://www.americanmuscle.com/cr-racing-radiator-0510gt.html http://www.americanmuscle.com/frpp-aluminum-radiator-0510gt.html https://lmr.com/item/FHP-2005MU/05-09-Fluidyne-Mustang-Aluminum-Radiator How hard is it to fit? I've heard clearance is tight. Should I get a new fan also? Thanks team, Quote Link to comment Share on other sites More sharing options...
JASPONY Posted July 15, 2016 Report Share Posted July 15, 2016 If your A/C is cutting off it's probably because the high speed fan relay is overheating/shorting/melted. The compressor won't engage if the fan isn't running. The underside of my fuse block actually melted from the heat from the relay. As far as the radiator goes I've had all the ones you listed the mishimoto, C&R and Fluidyne were all garbage and didn't last much more than a year. I'm running the ford racing one right now and wish I would have done that from the start. I also upgraded to the SVT/SVE (13-14 GT500) fan. Quote Link to comment Share on other sites More sharing options...
HARALD KELLEY Posted July 15, 2016 Report Share Posted July 15, 2016 Can you clarify. "Did not last much more than a year" did they leak, oxidize or ? Quote Link to comment Share on other sites More sharing options...
JASPONY Posted July 15, 2016 Report Share Posted July 15, 2016 Can you clarify. "Did not last much more than a year" did they leak, oxidize or ? They all started leaking. The C&R leaked from 3 different places. Quote Link to comment Share on other sites More sharing options...
Chance.316 Posted July 20, 2016 Author Report Share Posted July 20, 2016 Thanks for the heads up Jas. Quote Link to comment Share on other sites More sharing options...
2008GT-C Posted July 20, 2016 Report Share Posted July 20, 2016 I did the same upgrade as JASPONY. Both the radiator and fan were purchased on sale through a Ford Racing dealer on the internet. I posted a thread on this with photos. It is a tight fit but can be done in a day taking your time. Great upgrade for the money especially in a supercharged application. -Kevin Quote Link to comment Share on other sites More sharing options...
