mkgt500 Posted July 2, 2016 Report Share Posted July 2, 2016 Does anyone by chance know which fuse is for the interior trunk light on a 2010 GT500? I think i popped the fuse changing it to an LED bulb... Thanks Quote Link to comment Share on other sites More sharing options...
msb64 Posted July 3, 2016 Report Share Posted July 3, 2016 The fuse layout should be in your owners manual for that. Very unusual that installing an led light would have any affect on the circuit, unless the led assembly itself was shorted out somehow. Keep in mind that leds are polarity sensitive (directional), if it doesn't work one way, rotate 180 degrees and try again. Quote Link to comment Share on other sites More sharing options...
msb64 Posted July 3, 2016 Report Share Posted July 3, 2016 Checked my 08 manual and nothing is listed for that specifically, it may be part of another circuit. Have you noticed any other lighting not working, such as ambient or map lights? Also keep in mind that the trunk light will automatically turn off after awhile, if the trunk is left open for more than 5 - 10 min or so. Btw, you can verify your led bulb is good with a couple of small gauge wires and a 12v battery, so you know that is not the issue. Been running leds in my trunk, license plate, map and fog lights for years, and this year added led headlights. Big power savings with the leds and I like the cool white 5K light a lot more. Quote Link to comment Share on other sites More sharing options...
mkgt500 Posted July 3, 2016 Author Report Share Posted July 3, 2016 I was trying to pop the light out with a screwdriver since the light was hot... not a good idea. I finally figured it out. It is #25 ... All is working now. Thank you Quote Link to comment Share on other sites More sharing options...
