MtShelby Posted June 23, 2016 Report Share Posted June 23, 2016 Good morning. The clutch on my '07 GT500 started slipping the other day so it looks as though it's time for a replacement. There are a lot of options out there, so I was hoping some of you guys who have been through this might be able to tell me what you've found to be a good replacement. Any input would be greatly appreciated. Link to comment Share on other sites More sharing options...
Secondo Posted June 23, 2016 Report Share Posted June 23, 2016 Need to know more info on your car. HP level would be most helpful. Link to comment Share on other sites More sharing options...
MtShelby Posted June 23, 2016 Author Report Share Posted June 23, 2016 It's bone stock. Primary use is just highway travel. The original one was replaced under warranty under the campaign that included the transmission, clutch flywheel etc. That one lasted 41,000 miles but always was a bit finicky as far as trying to keep it from chattering. I need something that will handle the stock horsepower and hopefully be smoother than the factory original. It's not typically driven hard, but I want something that will hold up to a bit of abuse should I choose to start having a bit more fun with it....... Link to comment Share on other sites More sharing options...
Secondo Posted June 23, 2016 Report Share Posted June 23, 2016 Then I highly recommend the Ford 4th revision 2010 clutch/flywheel/slave cylinder replacement. Smooth like butter, durable, quiet and long lasting. Look for the topic in the GT500 Mods and Technical Clutch & Transmission forum. Link to comment Share on other sites More sharing options...
Cali_KR Posted June 27, 2016 Report Share Posted June 27, 2016 Then I highly recommend the Ford 4th revision 2010 clutch/flywheel/slave cylinder replacement. Smooth like butter, durable, quiet and long lasting. Look for the topic in the GT500 Mods and Technical Clutch & Transmission forum. Yup, have that on my KR...silky smooth... Link to comment Share on other sites More sharing options...
