RhinoRacing Posted May 17, 2016 Report Share Posted May 17, 2016 Has anyone installed a 2.9 Ford Racing Whipple on a KR? ( M-6066-MSVT29PC ) Did it fit under the hood? Without modifying the hood? Thanks Quote Link to comment Share on other sites More sharing options...
39Mustang Posted July 23, 2016 Report Share Posted July 23, 2016 Has anyone installed a 2.9 Ford Racing Whipple on a KR? ( M-6066-MSVT29PC ) Did it fit under the hood? Without modifying the hood? Thanks If you never got an answer to this ask Frank at Power by the Hour they will know Quote Link to comment Share on other sites More sharing options...
sheppd01 Posted July 24, 2016 Report Share Posted July 24, 2016 Yes it will fit under the hood and cross bar. If you buy the full kit the cold air intake will not fit under the hood and cold air intake tube does not fit under the cross bar. There is a work around..... I have a picture somewhere. ? Quote Link to comment Share on other sites More sharing options...
RhinoRacing Posted July 28, 2016 Author Report Share Posted July 28, 2016 Thanks for the info pics would be great. I assume the filter housing and filter from the KR can be reused, it will be the tube that is the issue. Quote Link to comment Share on other sites More sharing options...
sheppd01 Posted July 28, 2016 Report Share Posted July 28, 2016 I am on vacation. I will check my computer when I get back home. Quote Link to comment Share on other sites More sharing options...
RhinoRacing Posted July 29, 2016 Author Report Share Posted July 29, 2016 Thanks that would be great! Quote Link to comment Share on other sites More sharing options...
sheppd01 Posted August 8, 2016 Report Share Posted August 8, 2016 Quote Link to comment Share on other sites More sharing options...
RhinoRacing Posted August 9, 2016 Author Report Share Posted August 9, 2016 Thanks for the pics! Got a couple of questions. 1). Are the motor mounts stock? 2). The intake tube and meter housing, what car are they from? 3). With changing the inlet tube and meter were you able to use the supplied tune from Ford? Thanks for the help! Quote Link to comment Share on other sites More sharing options...
sheppd01 Posted August 9, 2016 Report Share Posted August 9, 2016 (edited) It's not my car but from what I was told the motor didn't have to be lowered. The intake tube and filter box is original. The meter tube housing is from ford. From what I was told you need to call Ford Racing and tell them you have a KR and the kit they send you should come as seen in the pics. Edited August 9, 2016 by sheppd01 Quote Link to comment Share on other sites More sharing options...
RhinoRacing Posted August 10, 2016 Author Report Share Posted August 10, 2016 Ok thanks! Meter looks like the one they used on the 08 Cobra Jet. I talked to John Clor at Ford Performance (old Ford Racing) he looked at my car in person said that the kit will not fit under the brace. When asked why he said the supercharger clears the brace and the hood. But it will be the intake tube that doesn't clear the brace do to the increase in diameter. Soooo I am guessing the kit changed. As long and the supercharger clears the hood I'm good! I will try the stock tube and dyno the car to see if it throws off the Ford supplied tune. I would like the brace to work also but if it hits then I can mod the brace or reproduce the rare Super Snake flat one. Thanks a lot for the pics and the info!!!!!!!!!!!!!! this will be a winter project of mine so when it is done I will post how it turned out Quote Link to comment Share on other sites More sharing options...
msb64 Posted August 11, 2016 Report Share Posted August 11, 2016 I had to mod my KR style brace as well to clear a JLT 123mm intake tube, maybe yours will be similar. http://www.teamshelby.com/forums/index.php/topic/88105-strut-tower-brace-mod/ Quote Link to comment Share on other sites More sharing options...
RhinoRacing Posted August 12, 2016 Author Report Share Posted August 12, 2016 Great idea was thinking the same thing! Glad to see it works! Quote Link to comment Share on other sites More sharing options...
