99-9x Posted May 4, 2016 Report Share Posted May 4, 2016 Has anyone used a clear plastic car cover( the type usually seen in body shops)? Black SGT shows dust and pollen as soon as I finish detailing it. Was thinking about using an inexpensive cover in between use but not sure of any issues. Small enough to put in the bag and leave in the trunk. I found on Amazon for under $10.My garage has a concrete floor. Quote Link to comment Share on other sites More sharing options...
SAI-Steven Posted May 4, 2016 Report Share Posted May 4, 2016 Has anyone used a clear plastic car cover( the type usually seen in body shops)? Black SGT shows dust and pollen as soon as I finish detailing it. Was thinking about using an inexpensive cover in between use but not sure of any issues. Small enough to put in the bag and leave in the trunk. I found on Amazon for under $10.My garage has a concrete floor. I wouldn't use it if it was me. Plastic sheeting has two major problems, well actually maybe three major problems. First problem, it will trap/retain moisture because it doesn't breathe Second problem is the plastic can "off-gas" which may cause staining to your stripes and or paint. Third problem is that plastic sheeting will cause major static electricity which may intensify dust & pollen issues on the car. There are plenty of good quality car covers made out of thin material that doesn't take up much trunk space at all. Steve Quote Link to comment Share on other sites More sharing options...
SoCalSGT Posted May 4, 2016 Report Share Posted May 4, 2016 I agree with Steve. If you just want a dust cover, there are many cover manufacturers that make single layer cloth covers that have a protective liner. they won't work in the weather but are fine for a garage. Don't use plastic for any length of time. I had one of those thin dust covers for my black SGT and it fit nicely in a small bag as long as I took the time to roll it up carefully. Remember, Black isn't a color, it's a career! Quote Link to comment Share on other sites More sharing options...
99-9x Posted May 4, 2016 Author Report Share Posted May 4, 2016 Thanks,Steve and SoCal,your right about black being a career instead of a color.I have 2 good covers but they are bulky,thought l found a short cut.Appreciate the input. Quote Link to comment Share on other sites More sharing options...
