Richard Stiles Posted November 9, 2015 Report Share Posted November 9, 2015 I found a factory 19" Mustang GT 2013 wheel with minor damage a couple hundred miles away. Since the GT has 19's on front I think it might fit. With the smallest used tire I can find for a spare, will it fit in the well in the trunk? If I got a flat on the rear I guess I would limp slowly to a tire shop. Quote Link to comment Share on other sites More sharing options...
Radical08 Posted November 14, 2015 Report Share Posted November 14, 2015 yes it fits 2010-2014 all the same lug pattern Quote Link to comment Share on other sites More sharing options...
Michael Meiring Posted December 29, 2015 Report Share Posted December 29, 2015 Remember that when it comes to rims for our GT500's, the clearance for the larger Brembo brake calipers is critical. While the rim bolt pattern may be the same, as well as the rim diameter and tire diameter, it still may not work as the rim will contact the brake caliper and not turn. Also, remember that even if the rim does clear, that running two different tire diameters on the rear axle can cause damage to the limited slip differential. In the case of a rear blowout, you may just have to put a front rim/tire on the rear and then the spare in front (assuming the front and rear tire diameters are the same). Just some things to think about!! Quote Link to comment Share on other sites More sharing options...
