Kook Posted October 21, 2015 Report Share Posted October 21, 2015 it is probably on here somewhere already, but do I need to retune my KR when I put the Stedda pulley on it? I had my gt500 dyno tuned, CAI, pulley and 3"cat back. heard kr tune will support pulley.?? don't want to hurt it. thanks Quote Link to comment Share on other sites More sharing options...
08KR525 Posted October 22, 2015 Report Share Posted October 22, 2015 (edited) From what I've been told the Steeda 2.65" pulley does not require a new tune when used on an otherwise stock 2008-2009 GT500KR. That said please do your homework and don't take my word for it. Also, you will require a 90mm idler to take up the belt slack created by installing the smaller pulley. GL Edited October 22, 2015 by 08KR525 Quote Link to comment Share on other sites More sharing options...
buster Posted October 22, 2015 Report Share Posted October 22, 2015 Put a TVS on that KR! Quote Link to comment Share on other sites More sharing options...
08KR525 Posted October 22, 2015 Report Share Posted October 22, 2015 I for once agree with Buster. I did the pulley swap on my KR only to swap to a fully ported and polished FRPP TVS along with a L&M High Flow elbow and 66mm tb. There are always deals to be had on TVS's if your patient and you'll wonder why you ever messed with the stock Eaton. Quote Link to comment Share on other sites More sharing options...
08krrick Posted October 23, 2015 Report Share Posted October 23, 2015 think if you do a tvs swap and a pulley less than 3in, you do need a tune. right? my tvs added 3 lbs of boost. pulley would add a couple more. might be too much for the KR tune. Quote Link to comment Share on other sites More sharing options...
Kook Posted October 26, 2015 Author Report Share Posted October 26, 2015 just the pulley, cheap HP. want to leave it pretty much stock, collector car and all. my 08 GT500 has kr wheels, kr suspension, pulley, CAI, 3" cat back, kr shifter (as soon as I install it). I guess put it on and try it. I can copy tune of 500 if its too lean. Any body use Stedda tune? I have 541 at tire with GT500. too bad tuners only work on one car. Quote Link to comment Share on other sites More sharing options...
shel-b001 Posted October 26, 2015 Report Share Posted October 26, 2015 I have the Steeda pulley, & idler bracket with their tune ,dyno resulted at 529 h.p at the rear wheels. Quote Link to comment Share on other sites More sharing options...
Kook Posted October 26, 2015 Author Report Share Posted October 26, 2015 Thanks, sounds pretty close to mine. 3" exhaust is probably diff. I didn't use idler, no issues with belt slip. Quote Link to comment Share on other sites More sharing options...
