gregsgs Posted September 23, 2015 Report Share Posted September 23, 2015 Well time has come and I need to change the oil. I have looked around and found 2 different ways to do it. can anyone tell me the right way to change the oil and cooler and if it needs to be done in any order. also how much oil is needed to do it. can I get the filter at most auto stores? any help would be great !! Quote Link to comment Share on other sites More sharing options...
08KR525 Posted September 23, 2015 Report Share Posted September 23, 2015 Just follow the owner's manual and don't put a cheap filter on it. Unless you want oil all over your k member take some aluminum foil and cover it directly under the oil filter before you remove it. Quote Link to comment Share on other sites More sharing options...
blk12svt Posted September 24, 2015 Report Share Posted September 24, 2015 You can also avoid a mess by placing a gallon zip lock baggy over your filter when you unscrew it. Quote Link to comment Share on other sites More sharing options...
Torched10 Posted September 24, 2015 Report Share Posted September 24, 2015 Get my motorctaft oil filter kit from k-man's parts Quote Link to comment Share on other sites More sharing options...
billross Posted September 24, 2015 Report Share Posted September 24, 2015 Walmart sells Motorcraft filters too. I just picked up an FL820S for my Shelby for $3.97. Quote Link to comment Share on other sites More sharing options...
Dave1968 Posted September 24, 2015 Report Share Posted September 24, 2015 8.5 quarts of Amsoil 5w50 signature series full synthetic and an Amsoil EA011 oil filter. Your shelby will thank you! Quote Link to comment Share on other sites More sharing options...
Z-man Posted September 24, 2015 Report Share Posted September 24, 2015 You can also avoid a mess by placing a gallon zip lock baggy over your filter when you unscrew it. That's a good idea! Quote Link to comment Share on other sites More sharing options...
