svtmattUT Posted August 28, 2015 Report Share Posted August 28, 2015 I bled the brakes for the first time and tightened the bleeder screw with what I thought was enough torque, obviously not as it leaked and sprayed on the wheel and trashed the finish . I have researched many forums and found nothing. The old 2011 manual a member posted years back (http://iihs.net/fsm/?dir=764&viewfile=SPECIFICATIONS.pdf ) states 89 lb-in but that was the old 4 piston brembos on a 2011 GT500. Anyone happen to know for a fact what the torque should be on 2013-2014 GT500 6 piston brembos? I also found the installation manual for a similar (no shelby) 6 piston brembo and it said 120 in-lb. Too much and you strip it, too little and it leaks. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
1 Alibi 2 Posted August 28, 2015 Report Share Posted August 28, 2015 I would contact Brembo, unless you know what size the screw is. Quote Link to comment Share on other sites More sharing options...
Snoopy49 Posted August 28, 2015 Report Share Posted August 28, 2015 Brake System — SPECIFICATIONS.pdf Quote Link to comment Share on other sites More sharing options...
svtmattUT Posted August 28, 2015 Author Report Share Posted August 28, 2015 Brake System — SPECIFICATIONS.pdf Exactly what I was looking for, thank you so much! 159 lb-in on 6 piston calipers is the official answer if google decides to index this for others. Quote Link to comment Share on other sites More sharing options...
