crazybobracing Posted June 26, 2015 Report Share Posted June 26, 2015 Just bought my 2013 Super Snake with 2500 miles. Changed the oil the other day and at start up it was around 75psi after warm up around 60psi but when reved up almost at 100psi... Is this normal because 100psi seems high. I am looking at the Shelby installed oil pressure gauge on the A pillar. Thanks Bob Quote Link to comment Share on other sites More sharing options...
william strauch Posted June 28, 2015 Report Share Posted June 28, 2015 75 - 80 tops Quote Link to comment Share on other sites More sharing options...
crazybobracing Posted June 28, 2015 Author Report Share Posted June 28, 2015 what would make mine read higher than normal???? gauge does zero out when car is off.. Quote Link to comment Share on other sites More sharing options...
william strauch Posted June 28, 2015 Report Share Posted June 28, 2015 Bob, I'm not the most technical guy in the group,so I can only tell you from what I know. The pump is higher volume standard. If it sounds good and runs good I personally would'nt worry. Quote Link to comment Share on other sites More sharing options...
crazybobracing Posted June 28, 2015 Author Report Share Posted June 28, 2015 I wonder if oil filter could change it..I used a K&N this last time Quote Link to comment Share on other sites More sharing options...
crazybobracing Posted June 28, 2015 Author Report Share Posted June 28, 2015 I changed oil as soon as i got car, I wish I would have paid attention prior to oil change.. Quote Link to comment Share on other sites More sharing options...
2007red40thGT500 Posted June 28, 2015 Report Share Posted June 28, 2015 glad im not the only person curious about that. my SAI guage pod shows anywhere friom 30-75. 75 after starting and as low as 30 after driving a while or idling at a stop. Quote Link to comment Share on other sites More sharing options...
real_supersnake Posted June 30, 2015 Report Share Posted June 30, 2015 Mine stays between 40 and 80, before and after oil change. Quote Link to comment Share on other sites More sharing options...
crazybobracing Posted June 30, 2015 Author Report Share Posted June 30, 2015 ok thanks Quote Link to comment Share on other sites More sharing options...
william strauch Posted July 1, 2015 Report Share Posted July 1, 2015 (edited) In reality I did just pay attention to my oil pressure. It was in fact upon starting around 90 psi. After driving for 5 mins. or so,it runs consistently 70-75 at rpms. 30@ idle. Edited July 1, 2015 by william strauch Quote Link to comment Share on other sites More sharing options...
crazybobracing Posted July 1, 2015 Author Report Share Posted July 1, 2015 ok thanks for checking... Quote Link to comment Share on other sites More sharing options...
shel-b001 Posted July 1, 2015 Report Share Posted July 1, 2015 I changed oil as soon as i got car, I wish I would have paid attention prior to oil change.. Did you stay with the recommended oil viscosity? Viscosity has a bearing on oil pressures. Quote Link to comment Share on other sites More sharing options...
crazybobracing Posted July 1, 2015 Author Report Share Posted July 1, 2015 Yes 5/50 Quote Link to comment Share on other sites More sharing options...
2007red40thGT500 Posted July 1, 2015 Report Share Posted July 1, 2015 yeah, actually mine also flutters erratically near 100 when it first starts, then runs somewhere between 30-75 the rest of the time. good to know. thanks. Quote Link to comment Share on other sites More sharing options...
