Ccopeland3 Posted June 14, 2015 Report Share Posted June 14, 2015 Got a MaxJax hoist and trying to put my SS on it. Can't seem to get past the CF ground effects. Tips?? Quote Link to comment Share on other sites More sharing options...
stngfever Posted June 14, 2015 Report Share Posted June 14, 2015 (edited) These work GREAT on all cars that are recommended to lift via pinch weld! I have 4 of them hanging on my 2 post lift and used them on my Shelby GT, 07 focus, Audi, and other pinch weld vehicles. http://www.zl1addons.com/index.php/shop-for-gear/jackpads-magpads/mustang-premium-jackpads-detail Here's PIC of my Shelby GT using these pads, you can see they provide plenty of clearance. Edited June 14, 2015 by stngfever Quote Link to comment Share on other sites More sharing options...
uford Posted June 16, 2015 Report Share Posted June 16, 2015 I use a floor jack under the rear end to lift the back of the car high enough to get the lift arms lined up under the car and then lower the floor jack. Do the same in reverse to take it off the lift. Works great! Quote Link to comment Share on other sites More sharing options...
stngfever Posted June 16, 2015 Report Share Posted June 16, 2015 (edited) Forgot to add that I have to drive all fours up on 2x6's to allow the arms to clear my SGT. Edited June 16, 2015 by stngfever Quote Link to comment Share on other sites More sharing options...
Ccopeland3 Posted June 18, 2015 Author Report Share Posted June 18, 2015 Stngfever, do the clips fit through the side skirts? I ended up taking the side skirts off. Putting them back on not so great unless you use all new clips. Thanks for the advice guys! Quote Link to comment Share on other sites More sharing options...
stngfever Posted June 18, 2015 Report Share Posted June 18, 2015 Assuming the SS skirts have the same openings at pinch weld as the gt's, yes they fit perfectly. The versions I pointed out have magnets to hold them in place. Best solution I found for lifting pinch weld vehicles. Quote Link to comment Share on other sites More sharing options...
Ccopeland3 Posted June 18, 2015 Author Report Share Posted June 18, 2015 Thanks. Got to get me a set of those. Quote Link to comment Share on other sites More sharing options...
1sgt Posted June 18, 2015 Report Share Posted June 18, 2015 Can you give us some pic using them on your car ?? Quote Link to comment Share on other sites More sharing options...
stngfever Posted June 18, 2015 Report Share Posted June 18, 2015 The pic I posted above was taken while using on my car. I'll get some better pics this weekend. Quote Link to comment Share on other sites More sharing options...
Ford Fest Posted June 18, 2015 Report Share Posted June 18, 2015 If you still have the rear brake cooling ducts on, you will not be able to lift on the rear pinch weld. I have the same issue on my 40th. Quote Link to comment Share on other sites More sharing options...
stngfever Posted June 22, 2015 Report Share Posted June 22, 2015 Close ups of Jackpads: Side skirts removed: Quote Link to comment Share on other sites More sharing options...
Ccopeland3 Posted June 22, 2015 Author Report Share Posted June 22, 2015 Picture worth a thousand words. Mine are on order. Thanks again. Quote Link to comment Share on other sites More sharing options...
