bmezz Posted June 3, 2015 Report Share Posted June 3, 2015 I bought an sct x4 tuner,downloaded the updater program all OK. Got 2 tunes and am trying to download them and put them on the tuner,when the updater program opens the window does not show everything and I can't make it bigger. Link to comment Share on other sites More sharing options...
MyBlueHeaven Posted June 3, 2015 Report Share Posted June 3, 2015 I bought an sct x4 tuner,downloaded the updater program all OK. Got 2 tunes and am trying to download them and put them on the tuner,when the updater program opens the window does not show everything and I can't make it bigger. I'm not quite following what your trying to say in your problem description, by download do you mean extract the file from its current location, like email? Upload is what you would be doing when you put the file on the tuner. it should be saved to a location first, like desktop or your C drive. Best bet though would be to give SCT tech support a call and they can get it figured out for you. They can even remote into your computer and load the tuner file for you if you wanted them to. info below if you didn't have it. http://www.sctflash.com/techarticle.php?TID=1 Technical Support by Phone: 407-774-2447 Jeff Link to comment Share on other sites More sharing options...
bmezz Posted June 3, 2015 Author Report Share Posted June 3, 2015 Not having "trouble" with the download, having trouble with the download "screen" I can't see the whole screen so I can see the buttons I have to press to start the download process. But thank you I'll try Tech support in the morning. Link to comment Share on other sites More sharing options...
Frank S Posted June 3, 2015 Report Share Posted June 3, 2015 I had that "partial screen" problem, got in touch with SCT "support", and after much ineffective "help", they essentially said "Tough S**t" and stopped responding to my communications. I'd entertain suggestions as to what "SCT" really means... Link to comment Share on other sites More sharing options...
Larry T Posted June 3, 2015 Report Share Posted June 3, 2015 Can you got back to where you bought the tuner? I have purchased one from AM and they were great with tunes for life and any issues that I may have been having. Link to comment Share on other sites More sharing options...
bmezz Posted June 3, 2015 Author Report Share Posted June 3, 2015 Talked to SCT program is good,told me it was probably a display problem after a few hours finally got it working all ok. had to go to ...Control Panel\Appearance and Personalization\Display Then made a custom display size of 135% and it worked after trying 4 or 5 different sizes, after every change in size you have to reboot computer. Link to comment Share on other sites More sharing options...
MyBlueHeaven Posted June 4, 2015 Report Share Posted June 4, 2015 Talked to SCT program is good,told me it was probably a display problem after a few hours finally got it working all ok. had to go to ...Control Panel\Appearance and Personalization\Display Then made a custom display size of 135% and it worked after trying 4 or 5 different sizes, after every change in size you have to reboot computer. Glad to hear it. After seeing the pic you posted I was thinking the same thing. I opened up mine and checked it, but I use a 22" HD TV as a monitor so it was already set to the highest aspect ratio and screen set to wide to accommodate the size of it. Jeff Link to comment Share on other sites More sharing options...
Frank S Posted June 6, 2015 Report Share Posted June 6, 2015 Talked to SCT program is good,told me it was probably a display problem after a few hours finally got it working all ok. had to go to ...Control Panel\Appearance and Personalization\Display Then made a custom display size of 135% and it worked after trying 4 or 5 different sizes, after every change in size you have to reboot computer. Thank you. That gives me some hope. The specialist who helped me couldn't come up with any reasonable steps to take before they abandoned me. I actually have two SCT tuners that are unlocked from cars I've sold on. They are useless to me now, but may be valuable to someone, or I might buy some tunes and try them on my current car. Link to comment Share on other sites More sharing options...
