Blacksnake1963 Posted May 26, 2015 Report Share Posted May 26, 2015 Anyone hear of a 4000 rpm cutout on my 2014 gt 500. I've went thru 3 sets of plugs and it's running rich on bank 2. Only 6000 miles on the car and it has mods including a bama tune. I hope it's not the upstream O2 sensor. Any ideas? Thanks Quote Link to comment Share on other sites More sharing options...
svtmattUT Posted May 26, 2015 Report Share Posted May 26, 2015 I would start with the tune. IMHO wouldn't trust an email tune from BAMA on a new GT500, especially if you have multiple/complicated modifications. Try vmptuning or Lundracing. I've run vmp on my last two shelbys spanning 5 years and have never seen mechanical damage. A $200 tune is much cheaper than a damaged engine. If you blowup the motor the dealership can read the duty cycles in the computer since it was last tuned. if they are very low to zero it's a red flag the end user Has reprogrammed it just before they came in with a damaged motor. Depending on how "cool" your dealership is you may or may not be faced with a repair bill. A highly experienced tuner is a must on a car that complex. Quote Link to comment Share on other sites More sharing options...
twobjshelbys Posted May 26, 2015 Report Share Posted May 26, 2015 I'd be surprised if you are not throwing an engine code. it sounds like it is going into "limp mode". If you change the air intake system (std box to CAI, throttle body), and/or exhaust (headers for sure, some mufflers) then you will likely need a tune to go with it. That is because those are the pre and post pump (engine) systems. CAIs and TBs allow more air in, headers/mufflers allow more exhaust out and both change the static AFR (Air-Fuel Ratio). Neither is a good thing. Did your system not come with the tuner? If it is just a static tune with no hardware changes than have you tried restoring the original tune? Quote Link to comment Share on other sites More sharing options...
Blacksnake1963 Posted May 26, 2015 Author Report Share Posted May 26, 2015 I have the smaller supercharger pulley, cai, off road h-pipe, corsa axle back, and the tune. It ran fine until I put the new plugs in. once I did that it hasn't run right since. I am waiting to hear from bama on tune questions and I'm looking at the up stream O2 sensor also from things I read on other forums. Thanks for the info and if there's any more out there I'll sure take it all in. Quote Link to comment Share on other sites More sharing options...
svtmattUT Posted May 26, 2015 Report Share Posted May 26, 2015 (edited) The factory 2013-2014 GT500 plugs are already a colder heat range, but should be gapped down to .028-.035" to prevent spark blowout, stock gap is 0.033 - 0.037 inches". Edited May 29, 2015 by svtmattUT Quote Link to comment Share on other sites More sharing options...
Blacksnake1963 Posted May 26, 2015 Author Report Share Posted May 26, 2015 (edited) Talked to Nick at JDM Engineering and he told me to put in the new plugs and go back to the stock tune and the car runs normal now so I guess it was something in the Bama tune. Don't think I'll be using Bama again. Just jike to give a shout out to Nick, he didn't have to help but he did. I'll be doing buisiness with JDM from here out. Edited May 26, 2015 by Blacksnake1963 Quote Link to comment Share on other sites More sharing options...
Snoopy49 Posted May 29, 2015 Report Share Posted May 29, 2015 (edited) From the 2013/14 GT500 Owners Manual Supplement V2 Spark plugs CGSF-12YP 0.033 - 0.037 inches (0.85 - 0.95 mm) Edited June 1, 2015 by Snoopy49 Quote Link to comment Share on other sites More sharing options...
08KR525 Posted May 29, 2015 Report Share Posted May 29, 2015 Talked to Nick at JDM Engineering and he told me to put in the new plugs and go back to the stock tune and the car runs normal now so I guess it was something in the Bama tune. Don't think I'll be using Bama again. Just jike to give a shout out to Nick, he didn't have to help but he did. I'll be doing buisiness with JDM from here out. I wouldn't think that you should still run your stock tune given that you still have all your other mods in place. I'm surprised the car hasn't at least thrown a lean code. Quote Link to comment Share on other sites More sharing options...
svtmattUT Posted May 29, 2015 Report Share Posted May 29, 2015 Stock gap is not .045" From the 2013/14 GT500 Owners Manual Supplement V2 Spark plugs CGSF-12YP 0.033 - 0.037 inches (0.85 - 0.95 mm) Right you are. For some reason VMP Tuning has this on thier 2013 GT500 pulley product description page. Lame. Good catch, I will update my post so there is no misinformation Quote Link to comment Share on other sites More sharing options...
Blacksnake1963 Posted June 12, 2015 Author Report Share Posted June 12, 2015 Went back to the stock tune and removed add ons and it ran fine. Just added ford racing throttle body, jlt big air intake and lund tune now it wont idle right. Pulling my hair out on this one. Quote Link to comment Share on other sites More sharing options...
07 Black Beauty Posted June 21, 2015 Report Share Posted June 21, 2015 I would definitely get a Lund or VMP tune, Bama is still pretty new when it comes to tuning gt500's. As said above $200 for a new tune is cheaper than $20,000 to rebuild a blown motor. Quote Link to comment Share on other sites More sharing options...
