magnonreyes Posted May 10, 2015 Report Share Posted May 10, 2015 So I have these new INVO tires, and now the pressure tire light is on. I decided to get a TPMS scanner trainer (motorcraft) now it is not working. any suggestions? thank you. Link to comment Share on other sites More sharing options...
Secondo Posted May 10, 2015 Report Share Posted May 10, 2015 I just trained mine. Is the L.E.D. light go on the trainer tool when pressing the button? I can send you the instructions if you don't have them. There's a sequence of steps that must be performed to put the car in TPMS Training mode. Link to comment Share on other sites More sharing options...
Doug_GT350 Posted May 11, 2015 Report Share Posted May 11, 2015 I just trained mine. Is the L.E.D. light go on the trainer tool when pressing the button? I can send you the instructions if you don't have them. There's a sequence of steps that must be performed to put the car in TPMS Training mode. that and if it has been awhile since the pressure was changed you may need to deflate or overinflate then reduce pressure to "wake up" the sensors, and yes all four tires must be woken up. Link to comment Share on other sites More sharing options...
magnonreyes Posted May 12, 2015 Author Report Share Posted May 12, 2015 Yes the LED light goes on when the green button is pressed, and I do have the instuctions, Thanks though. I will try to deflate and or overinflate the tires to " wake them". Once again guys thanks for the input. Link to comment Share on other sites More sharing options...
Doug_GT350 Posted May 12, 2015 Report Share Posted May 12, 2015 FWIW here's another thread on the subject that may help.... more and different info... http://www.teamshelby.com/forums/index.php/topic/83355-replacement-tpsm-sensors-not-recognized-by-computer-in-07-shelby-gt/?hl=tpms&do=findComment&comment=1494209 Link to comment Share on other sites More sharing options...
Secondo Posted May 13, 2015 Report Share Posted May 13, 2015 Can you be more specific? What isn't working, does it not get into training mode? The tool wont train the sensor? At what point does it not work?? Link to comment Share on other sites More sharing options...
