07SGTC Posted April 28, 2015 Report Share Posted April 28, 2015 Getting ready to install a set of Rear Baer Eradi speed drilled and slotted 14 inch rotors. Question is: Is there anything to look out for during the install? Will the Caliper Pistons need to be pressed back in if not removing the stock pads? The car has 8.000 miles on it and not really any hard braking. Any advice would be great. Link to comment Share on other sites More sharing options...
HARALD KELLEY Posted April 28, 2015 Report Share Posted April 28, 2015 I did this several years ago. Very simple. No issues at all. If I recall calipers slipped on rotors with no issues. Just do not let calipers hang by the brake lines. Not a best practice. Use a wire. Link to comment Share on other sites More sharing options...
07SGTC Posted April 28, 2015 Author Report Share Posted April 28, 2015 Thanks for the info. So no issues with the calipers slipping back over the bigger rotors when not changing pads or adjusting the piston back out? Link to comment Share on other sites More sharing options...
2008GT-C Posted April 28, 2015 Report Share Posted April 28, 2015 I agree with H0050. This mod was performed by myself a few years ago also. I do not recall having to put the pistons back in the caliper. As a reminder these pistons are not pressed in but turned in because of the internal e-brake. If an adjustment was needed it will be minimal. -Kevin Link to comment Share on other sites More sharing options...
MTYQIN Posted April 29, 2015 Report Share Posted April 29, 2015 I changed mine out in my garage a couple months ago. Like the other guys have noted, a straightforward install. No issues or problems. Look great, work fine. Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted April 29, 2015 Report Share Posted April 29, 2015 Thanks for the info. So no issues with the calipers slipping back over the bigger rotors when not changing pads or adjusting the piston back out? I had to back my caliper pistons in when i did mine. Nothing terrible, just one or two turns. I probably could'a got away without but they were too tight for my liking. I turned mine with a big pair of channel lock (water pump) pliers. Phill Link to comment Share on other sites More sharing options...
07SGTC Posted May 1, 2015 Author Report Share Posted May 1, 2015 Thanks for all the info! I completed the job last night. Big visual difference!! Did not have time to drive just pumped the brakes a few times and backed out of the garage and back in. The test will be later today. Link to comment Share on other sites More sharing options...
HARALD KELLEY Posted May 2, 2015 Report Share Posted May 2, 2015 Thanks for all the info! I completed the job last night. Big visual difference!! Did not have time to drive just pumped the brakes a few times and backed out of the garage and back in. The test will be later today. Glad it worked out for you! Link to comment Share on other sites More sharing options...
