h2odr Posted June 8, 2007 Report Share Posted June 8, 2007 has anyone installed california special side scoops on their gt 500? i have not looked into them yet, but i think they will make the car look nasty like the supersnake. i assume you must drill holes in the side of the car? i would appreciate any feed back i can get. thank you. Link to comment Share on other sites More sharing options...
ColdwaterHotrod Posted June 8, 2007 Report Share Posted June 8, 2007 I think after you have them painted you use 3M double side tape that comes with them. Also welcome to the board newbe Link to comment Share on other sites More sharing options...
Pointcover Posted June 8, 2007 Report Share Posted June 8, 2007 has anyone installed california special side scoops on their gt 500? i have not looked into them yet, but i think they will make the car look nasty like the supersnake. i assume you must drill holes in the side of the car? i would appreciate any feed back i can get. thank you. Talk to ShelbyDude. His look great! Link to comment Share on other sites More sharing options...
ShelbyDude Posted June 8, 2007 Report Share Posted June 8, 2007 has anyone installed california special side scoops on their gt 500? i have not looked into them yet, but i think they will make the car look nasty like the supersnake. i assume you must drill holes in the side of the car? i would appreciate any feed back i can get. thank you. The scoops that come on the CA Special require drilling two holes to install them. I got mine from Cervinis. www.cervinis.com I got the upper and lower side scoops. These are installed with the 3M tape. They will have to be prepped, sanded, primed, wet sanded, painted and clearcoated. So there is some work involved. I had our body shop do mine. I think it was about $356 for both upper and lower scoops together, plus whatever you can find a body shop to charge for prepping and installing them. Link to comment Share on other sites More sharing options...
ShelbyDude Posted June 8, 2007 Report Share Posted June 8, 2007 Here are a couple pics of my scoops Link to comment Share on other sites More sharing options...
Revans310 Posted June 9, 2007 Report Share Posted June 9, 2007 Here are a couple pics of my scoops WOW very nice. Link to comment Share on other sites More sharing options...
mach1fever Posted June 9, 2007 Report Share Posted June 9, 2007 looks amazing Link to comment Share on other sites More sharing options...
h2odr Posted June 9, 2007 Author Report Share Posted June 9, 2007 looks amazing I agree, these scoops look awesome! do they secure really well? i realize you have not had them on all that log, is there a projected life exceptance of the 3m tape? i will hate to put anything onto may car ( when it gets here) that will damage it in the long run. in person, do your lower side scoops look just like the c/s's? Link to comment Share on other sites More sharing options...
ShelbyDude Posted June 9, 2007 Report Share Posted June 9, 2007 I agree, these scoops look awesome! do they secure really well? i realize you have not had them on all that log, is there a projected life exceptance of the 3m tape? i will hate to put anything onto may car ( when it gets here) that will damage it in the long run. in person, do your lower side scoops look just like the c/s's? The lower scoops are a little wider in the opening. They are open where the C/S scoops are closed off with a plastic piece. The upper scoops are open as well, but there is a metal screen piece covering the opening mounted from the inside. I have had these since I started driving the car this year. I have been up to 140 MPH several times and many times over a 100 MPH. They have been holding up well with no problem. I was concerned with the scoops being open that the wind build up may cause a problem with forcing them to come loose. No problems though. There is a noticeable wind noise because of the air blowing into the openings if the windows are down at higher speeds. Other than that they are holding up great and they do look great. That 3M tape is some strong stuff! The guy in our body shop that put these on put the car inside the paint booth and let it sir for awhile with the heat turned up. He said that heat would really suck them tight to the car and make them stick better. So far I guess he is right! These are the same scoops Crevinis uses on their C-300 kit so I guess they must hold up pretty good or they would not be using them. If they ever did come loose they can be easily fixed by replacing the 3M tape. Link to comment Share on other sites More sharing options...
arizonabud Posted June 9, 2007 Report Share Posted June 9, 2007 has anyone installed california special side scoops on their gt 500? i have not looked into them yet, but i think they will make the car look nasty like the supersnake. i assume you must drill holes in the side of the car? i would appreciate any feed back i can get. thank you. On the side scoops, www.hubcapsplus.com advertising them. They are stick on with 3M tape, already painted. I just got and installed their, painted mirror covers tonight in perf. white. Took about 10 minutes including a coat of wax when done. Match on color is perfect. I am considering a set of louvers they offer that are also stick on and painted. Anyone put their "louver" product on any of the cars out there and how do you like them? I think they really look good. AZbud Link to comment Share on other sites More sharing options...
mach1fever Posted June 9, 2007 Report Share Posted June 9, 2007 Thanks for the info Shelby dude. I can attest to the 3m tape. Most body kits are attatched in this manner, and my car will see strip duty so I was concerned about the scoops being open. Thanks again, Roger Link to comment Share on other sites More sharing options...
bill0754 Posted June 10, 2007 Report Share Posted June 10, 2007 I have been thinking of adding the ones from 3D Carbon. They sell on Ebay prepainted for around $230 + $15 shipping. They look great, and also just stick on with 3M tape. They are closed with a black grille, so no worries of wind noise or air build up. Link to comment Share on other sites More sharing options...
h2odr Posted June 10, 2007 Author Report Share Posted June 10, 2007 Thank you for the responses, i looked at all of them. i really like the idea of recieving them already painted. ( hubcapsplus.com) get em, and on they go. the upper and lower scoops just make these cars look nasty. any thoughts out there on the best axle back bolt on mufflers? i had rented a hertz shelby and liked the sound of it, only if it was a touch deeper at slow speeds. Link to comment Share on other sites More sharing options...
