lpfd10 Posted January 29, 2015 Report Share Posted January 29, 2015 I have an 09 GT500 purchased new 7,000 miles...around tight turns the rear growls...dealer says its normal....any input....Thanks Link to comment Share on other sites More sharing options...
shel-b001 Posted January 29, 2015 Report Share Posted January 29, 2015 I have an 09 GT500 purchased new 7,000 miles...around tight turns the rear growls...dealer says its normal....any input....Thanks Could be the clutch packs they can be a little noisy. Try taking it to an open parking lot & do some fiqure eights , this squeeze the rear lubricant into the clutch packs. Also may try added 3.oz anti friction which Ford sells . Also if you do a bit of burn out & you have one wheel laying down a dark strip & the other is very light is good indication its the clutch packs which need lubricating by doing a fiqure eight.. Good Luck let us know if this solves it .( It has for several others) Link to comment Share on other sites More sharing options...
