Sasquatch Posted November 4, 2014 Report Share Posted November 4, 2014 I would like to get these wheels for my stock 08 GT500 and I was wondering what would be the best tire make and size for this application? Also, with this setup would the car need to be lowered to not only look right, but to accomdate the larger tires and wheels? At this point tires, wheels and suspension are stock. I figured a few of you had been there and done that so you could offer valuable advise (maybe some pictures). Thank you in advance and I apologize if this has been asked numerous times. Link to comment Share on other sites More sharing options...
2007tungstenGT500 Posted November 4, 2014 Report Share Posted November 4, 2014 opinions will vary, but i believe 20" looks best for these (and most other aftermarket wheels) on our cars. and yes, you will need lowering springs, at a minimum to make them look right. especially with respect to the rear wheel well, which is already high with the stock rims/tires. Link to comment Share on other sites More sharing options...
Sasquatch Posted November 4, 2014 Author Report Share Posted November 4, 2014 Thank you for your feedback. Do you have a tire size suggestion? I will probably stick with 20 x 9 in the front and 20 x 10 in the back. Also, when lowering the car is springs all I need, or do I need some type of suspension / handling kit? Link to comment Share on other sites More sharing options...
car dude Posted November 4, 2014 Report Share Posted November 4, 2014 Thank you for your feedback. Do you have a tire size suggestion? I will probably stick with 20 x 9 in the front and 20 x 10 in the back. Also, when lowering the car is springs all I need, or do I need some type of suspension / handling kit? You will need a adjustable lanyard bar. If not when you lower the rear your rearend will stick out further to one side then the other. Link to comment Share on other sites More sharing options...
JeffJ Posted November 4, 2014 Report Share Posted November 4, 2014 You will need a adjustable lanyard bar. If not when you lower the rear your rearend will stick out further to one side then the other. Ha...ha... Looks like you got spell checked. I believe you mean Panhard bar. Link to comment Share on other sites More sharing options...
Sasquatch Posted November 4, 2014 Author Report Share Posted November 4, 2014 Will this kit do the job? http://www.shelbystore.com/product-p/Z15-M-FR3A-MSVTB.htm Link to comment Share on other sites More sharing options...
mavisky Posted November 4, 2014 Report Share Posted November 4, 2014 If you're looking for an affordable but effective lowering kit, I'd suggest the GT500KR suspension set. You can find them on Ebay for around the $190-200 mark + shipping. Have the setup on mine and it was an easy install and works and looks much better than stock while retaining a nice ride for a daily driver like mine. Link to comment Share on other sites More sharing options...
2007tungstenGT500 Posted November 5, 2014 Report Share Posted November 5, 2014 Will this kit do the job? http://www.shelbystore.com/product-p/Z15-M-FR3A-MSVTB.htm yes, sure. but you can get by for less if you have to. to lower the car and make it visually appealing with the new tires, all you really need is springs, which are significantly cheaper. the panhard bar is not mandatory, but the more you lower it from stock, the more it will shift the entire rear axle the one side. panhard bar is pretty cheap, so i would (and i did on mine). as far as tires are concerned, i'd stick with 255 upfront and 295/305 if you have 10" in back. you can do your own research by plugging in the numbers here... http://www.rimsntires.com/specspro.jsp Link to comment Share on other sites More sharing options...
car dude Posted November 6, 2014 Report Share Posted November 6, 2014 Ha...ha... Looks like you got spell checked. I believe you mean Panhard bar. I hate when that happens. It changes the word after I moved on to typing new ones Link to comment Share on other sites More sharing options...
car dude Posted November 6, 2014 Report Share Posted November 6, 2014 I used BMR adjustable panhard bar and lower control arms. I also install a Roush wheel hop eliminator and Steeda springs. Link to comment Share on other sites More sharing options...
Coachmoe Posted November 6, 2014 Report Share Posted November 6, 2014 I would like to get these wheels for my stock 08 GT500 and I was wondering what would be the best tire make and size for this application? Also, with this setup would the car need to be lowered to not only look right, but to accomdate the larger tires and wheels? At this point tires, wheels and suspension are stock. I figured a few of you had been there and done that so you could offer valuable advise (maybe some pictures). Thank you in advance and I apologize if this has been asked numerous times. Here's my 2007. 20x9 fronts, 20x10 rear. Nittos NT555, 255/35-20 fronts, 285/30-20 rear. All I have for suspension mods are a set of Bob's LCA's. Did not want to lower the car because, A) I personally don't like lowered cars and B) I don't want to chew up the carbon fiber splitter. Link to comment Share on other sites More sharing options...
judgeman6970 Posted November 9, 2014 Report Share Posted November 9, 2014 Here's my '09 GT500. 255/35/20 up front 295/30/20 in the rear.... Link to comment Share on other sites More sharing options...
