braztang Posted October 14, 2014 Report Share Posted October 14, 2014 Hello there, The noise is from the differential (AXLE) under car when you are cruising you can hear a very loud whining. I owned a 2013 GT500 and had the same noise, but never bother to ask anyone as it was not so pronounced MAYBE. Now I decided to ask you guys out there if you find the same, so I can clear my mind. Appreciate any input. Cheers LCL Quote Link to comment Share on other sites More sharing options...
1 Alibi 2 Posted October 15, 2014 Report Share Posted October 15, 2014 There have been reports of gear whine on other sites, it's part of the drive train, take it to the dealer & have it fixed on Ford's dime. Quote Link to comment Share on other sites More sharing options...
SVTracer14 Posted October 15, 2014 Report Share Posted October 15, 2014 Lots of reports on the gear whine for the 13-14 MY cars, I suspect that having the gears replaced would be a band aid, and the symptoms would eventually come right back after some spirited driving. Either way, at least take it to Ford to have it documented and diagnosed. Quote Link to comment Share on other sites More sharing options...
shel-b001 Posted October 15, 2014 Report Share Posted October 15, 2014 Sounds like clearance problem , rear nds shouldn `t have a real noticable WHINE. Quote Link to comment Share on other sites More sharing options...
SVTracer14 Posted October 16, 2014 Report Share Posted October 16, 2014 Sounds like clearance problem , rear nds shouldn `t have a real noticable WHINE. What clearance problem are you referring to? The '13-14 MY cars are having a lot of problems with gear/rear end whine, but I'm not sure what it's attributed to. Quote Link to comment Share on other sites More sharing options...
Secondo Posted October 16, 2014 Report Share Posted October 16, 2014 The clearance between the pinion and ring gear teeth. I'm sure the parts themselves are high quality but may be assembled on the more reliable side (noisy) of the specs due to the high powered design of the drivetrain. Quote Link to comment Share on other sites More sharing options...
SVTracer14 Posted October 16, 2014 Report Share Posted October 16, 2014 The clearance between the pinion and ring gear teeth. I'm sure the parts themselves are high quality but may be assembled on the more reliable side (noisy) of the specs due to the high powered design of the drivetrain. And that might very well be the case. Interestingly enough, many of the people who are experiencing this problem are having it ocurr after several thousand miles. Mine started at about 1400 miles. Quote Link to comment Share on other sites More sharing options...
braztang Posted November 10, 2014 Author Report Share Posted November 10, 2014 Now, Would it be a problem to take the car to Dealer for diagnosing or warranty fixing it if you have added a SCT tune and a Cold Air Intake? Any inputs are welcome. Thanks LCL Quote Link to comment Share on other sites More sharing options...
braztang Posted November 10, 2014 Author Report Share Posted November 10, 2014 Just scheduled an appointment with FORD to see the issues of: 1- Squeaky body/control arms noise under driver's side at low speeds 2- Differential/power train whining noise when in cruise Service depto. advised that if car has a tune/CAI, it voids warranty! Is that correct? as these are not related to engine? Thanks all, LCL Quote Link to comment Share on other sites More sharing options...
