07ShelbyGT2908 Posted September 17, 2014 Report Share Posted September 17, 2014 Hey Guys Just bought the new and improved grille housing for my 07 Shelby GT. Question. How do you undo the tabs on the housing that's connected to the bumper. It looks like there is a little lever you pull to slide the tab out but I don't want to break anything so I want to ask for advice before I start! Thank you for your time, -Francis #2908 Quote Link to comment Share on other sites More sharing options...
Blown Away Posted September 18, 2014 Report Share Posted September 18, 2014 It's been a while since I changed mine out and can't remember if I did it with the bumper cover off or not, but I just pushed them over with my fingers. It's not difficult at all. It sucks getting old Dan Quote Link to comment Share on other sites More sharing options...
2007_Shelby_GT Posted September 18, 2014 Report Share Posted September 18, 2014 The tabs you mention are a little awkward to work with, but if you take things slow, the grill housing comes out very easily, with the grill still attached. The black plastic grill housing has knife-like blades with a notch that fits into the tabs on the front fascia. Remove the top radiator shroud first, then start from one side and work across to the other, (I think there's six total, but I haven't done this in a while), with the grill housing. You may have to use a padded screwdriver to open up the tabs and work the blade out just past the notch, then move on to the next one - don't attempt to pull the housing out until you've released all of the tabs, there should be enough play in the housing to allow this to happen. Once all blades have been released, gently work the housing straight out. You may have to go back and re-release some of the tabs if you allow the housing to slip back toward the engine. Sam Quote Link to comment Share on other sites More sharing options...
