fatboy Posted August 16, 2014 Report Share Posted August 16, 2014 Thought I'd add this thread (unless there is one already, but couldn't find it.) Just fixed my door panel that was peeling off. The solution was Automotive Goop. It comes in a tube. I tried 3m spray and other spray adhesives and they don't work. The goop is a little messy, but cleans right off incase you get any excess on the door. the stuff reminds me of modeling glue. It had the familiar fumes. Make sure you have area well ventilated. Link to comment Share on other sites More sharing options...
1badsgt Posted August 16, 2014 Report Share Posted August 16, 2014 Thanks for the info. My drivers door just did the same thing and I was wondering how I was going to fix it. Was going to try the 3M, but it sounds like that is not one of the better options. Link to comment Share on other sites More sharing options...
fatboy Posted August 16, 2014 Author Report Share Posted August 16, 2014 When i tried the spray adhesive it was a hot and humid day. So i dont know if that was a factor or not. i bought a cheap 2 inch wide paintbrush to apply to the goop to the back of the peeled vinyl. Just apply it right up to the top edge too so when you stick it back on the door u can take a putty knife to get the edge into the grove of the door paneling. i didnt have a putty knife so i used part of one of those wooden clothes pins. the end of them is pointy enough to push the peeled vinyl cloth back into the groving. just scrape off the excess as the goop oozes out of the edge of the vinyl. You dont have to use a lot on the vinyl but make sure your thorough along the edges. doesnt have to be real thick. I barely used any from the tube. Probably since the vinyl was still a bit sticky from the spray i tried using from before. after u get the vinyl back on, just massage it and keep wedging into the groving. After a few minutes it should hold. let it sit a while with windows down so it will air out the car. Link to comment Share on other sites More sharing options...
ChicagoChris Posted August 16, 2014 Report Share Posted August 16, 2014 Can u post of picture of the where on the door the vinyl was pealing? Link to comment Share on other sites More sharing options...
fatboy Posted August 16, 2014 Author Report Share Posted August 16, 2014 Can u post of picture of the where on the door the vinyl was pealing? let me take a pic and i'll upload it. Link to comment Share on other sites More sharing options...
fatboy Posted August 16, 2014 Author Report Share Posted August 16, 2014 i forgot how to upload pics. do i need to link it to a URL? never mind i figured it out..... Link to comment Share on other sites More sharing options...
fatboy Posted August 16, 2014 Author Report Share Posted August 16, 2014 i highlighted the area with red where it peeled away from the door. It was hanging all the way down to the inside door handle. Link to comment Share on other sites More sharing options...
ChicagoChris Posted August 16, 2014 Report Share Posted August 16, 2014 Great thanks. I'll check out my SGT tomorrow. Link to comment Share on other sites More sharing options...
19again Posted August 17, 2014 Report Share Posted August 17, 2014 Chris is this something just for the 07/08's? Link to comment Share on other sites More sharing options...
ChicagoChris Posted August 17, 2014 Report Share Posted August 17, 2014 Rich-Not sure as this is the first I've read about it. Link to comment Share on other sites More sharing options...
fatboy Posted August 18, 2014 Author Report Share Posted August 18, 2014 i think i might have read something about it on mustangforums.com. its been a while though. Link to comment Share on other sites More sharing options...
07SGT0517 Posted August 18, 2014 Report Share Posted August 18, 2014 I have repaired both of my doors. The key is to rub away the excess foam layer. That foam layer is is what actually fell apart. Link to comment Share on other sites More sharing options...
MJGordon Posted November 9, 2014 Report Share Posted November 9, 2014 I'll second that 0517. Hot Southern climate issue w foam cushion layer breaking down and separating they say. Mine finally began to come lose this past summer. Link to comment Share on other sites More sharing options...
DrKSGT Posted November 9, 2014 Report Share Posted November 9, 2014 Chris is this something just for the 07/08's?Rich, Interesting that the topic shows up now. Recent SAAC meeting a member was asking on how to fix his 2005 Mustang GT and his wife's 2008 Shelby GT. Her SGT is in Texas with hotter climate that explains her having issues. His GT is always in the Detroit area. Glad this solution got posted. Tom Link to comment Share on other sites More sharing options...
2007tungstenGT500 Posted November 10, 2014 Report Share Posted November 10, 2014 so you didn't have to remove the door panel? just repaired it on the door, as-is? Link to comment Share on other sites More sharing options...
LGSchmidtJr Posted November 10, 2014 Report Share Posted November 10, 2014 I have repaired both of my doors. The key is to rub away the excess foam layer. That foam layer is is what actually fell apart. fatboy Did you remove the foam layer like 0517 mentioned? If so, what is the best way to do this? My niece has an 05 Mustang which needs both panels repaired, and the drivers door on my car needs to be repaired and I want to do this soon. Thank you. Link to comment Share on other sites More sharing options...
