DatShelby Posted July 10, 2014 Report Share Posted July 10, 2014 I've been on another couple forums but just want to get everyones opinon is this is bothering the heck out of me. Past 20mph, not even driving hard, 2nd gear turns into a huge annoyance, it's as if instead of just popping in like butter when not moving, it becomes a 2-step process (CLICK-CLICK) and you literally have to YANK it into 2nd, same with down-shifting into 2nd. I've heard of a lot of 1-2 problems, but this happens when not really getting on it (as well as getting on it, getting on it you have to force the thing big time), say if I downshift into 2nd @ 20-30mph, I have to really PULL it into 2nd, not moving it goes back and forth with no problem what so ever. IS this the actual 1-2 problem everyone is talking about or something else? As mine does it going from 3rd to 2nd as well, and I feel like over-time this is for sure going to damage it, aside from being annoying as well. Link to comment Share on other sites More sharing options...
ShelbyGT5HUN Posted July 11, 2014 Report Share Posted July 11, 2014 Could be the shifter bushings binding up. I have noticed this problem as well with my shifter. No grind, but a 2 step process, like you described. Link to comment Share on other sites More sharing options...
IngotSilverSnake Posted July 14, 2014 Report Share Posted July 14, 2014 This "notchy" shift characteristic is normal for the TR6060 transmission. I contacted Tremec about this soon after I bought my car (mid year 2012) and that is what they told me. The transmission uses heavy duty hardware that contributes to increased rotating inertia and thus a perceived ‘notchy’ feel in the shift action. The short throw shifter adds to the increased shifting effort. They also said the all shifts with this heavy duty transmission must be "firm and deliberate." It is the nature of the beast. Changing the fluid to Mobil 1 ATF will help. It is the only synthetic fluid tested and approved by Tremec (at least at the point in time I contacted them). Link to comment Share on other sites More sharing options...
ghladysh Posted May 29, 2015 Report Share Posted May 29, 2015 I had the first to second shift problem in my 2012 GT500. I took it to Surprise Ford in Surprise, AZ and they rebuilt it under warranty. They replaced first and second gear as well as the first/second synchro assembly and the third/fourth synchro assembly. I works better than new. However, a firm and deliberate hand is an absolute necessity, just as IngotSilverSnake said. Be safe. Have fun. Share the experience. Link to comment Share on other sites More sharing options...
RazorbackMustang Posted September 10, 2015 Report Share Posted September 10, 2015 This was a "from day one" experience in my 2010 GT500. And on quick, hard shifts it would absolutely refuse to go into 2nd. I didn't have the car (or drive it enough) long enough to take it back to the dealer as I traded it for my current car. I chalk it up to the TR6060, of which I'm not a fan. Link to comment Share on other sites More sharing options...
