gotoatz Posted May 31, 2014 Report Share Posted May 31, 2014 Greetings to all, Quick question for anyone that has done a rim swap or tire replacement. ON the 2011, are the stock TPMS sensors the type that are held on the rim with a steel band all the way around, or, are they the type that are kinda sensors on the end of the valve stem?? Thank you, Mike Link to comment Share on other sites More sharing options...
Robert M Posted May 31, 2014 Report Share Posted May 31, 2014 Greetings to all, Quick question for anyone that has done a rim swap or tire replacement. ON the 2011, are the stock TPMS sensors the type that are held on the rim with a steel band all the way around, or, are they the type that are kinda sensors on the end of the valve stem?? Thank you, Mike It should be the stem type TPMS on a 2011. An indicator would be the stem itself, does it have a hex looking area under the cap? or just a plain old smooth rubber stem? Below is a picture of what the stem type TPMS valve stem will look like.............. The picture below is of a valve stem used with the band type TPMS.............. R Link to comment Share on other sites More sharing options...
Wharf Rat Posted May 31, 2014 Report Share Posted May 31, 2014 2011 is valve stem style. Link to comment Share on other sites More sharing options...
