68flashback Posted May 27, 2014 Report Share Posted May 27, 2014 When I bought my car the prior owner had invested in a Spec clutch. It works great but I need to work our my leg to be able to push the pedal down! I'm not mechanically inclined and was wondering if that is because of the clutch, or is this a spring(s) that can be changed or adjusted? As usual all help greatly appreciated! Link to comment Share on other sites More sharing options...
Triumph Posted May 28, 2014 Report Share Posted May 28, 2014 The Spec clutch is designed to hold a lot more torque than the stock clutch, and as such requires more pedal effort to release it. The clutch is activated with a hydraulic slave cylinder. Sorry, but as far as I know there isn't any adjustment available. Link to comment Share on other sites More sharing options...
jerseygator Posted May 28, 2014 Report Share Posted May 28, 2014 The Spec clutch is designed to hold a lot more torque than the stock clutch, and as such requires more pedal effort to release it. The clutch is activated with a hydraulic slave cylinder. Sorry, but as far as I know there isn't any adjustment available. +1 Link to comment Share on other sites More sharing options...
68flashback Posted May 29, 2014 Author Report Share Posted May 29, 2014 Thanks to Triumph and Jersey for the replies! Good to know. Just have to hit the gym a bit more I guess!!! Link to comment Share on other sites More sharing options...
