frazierfreud Posted May 9, 2014 Report Share Posted May 9, 2014 Why is it that oil dipsticks can't be black and white? Where should the oil be on the stick when filled properly? There is a small hash marked section. There is also two small dots well above the hash marks. Anyone know? Link to comment Share on other sites More sharing options...
Torched10 Posted May 9, 2014 Report Share Posted May 9, 2014 read page 232 in your manual---the hash marks are min and max points for oil Link to comment Share on other sites More sharing options...
Bookwyrm Posted May 9, 2014 Report Share Posted May 9, 2014 As Torched10 said, the top and bottom of the hash marks are the min/max for oil. From what I've read elsewhere, the dots are for factory use as an initial fill lines on cars equipped with the SVT Performance Pack to account for the extra ~1qt of oil that will generally be stuck in the oil cooler system and never be fully drained. Link to comment Share on other sites More sharing options...
frazierfreud Posted May 9, 2014 Author Report Share Posted May 9, 2014 As Torched10 said, the top and bottom of the hash marks are the min/max for oil. From what I've read elsewhere, the dots are for factory use as an initial fill lines on cars equipped with the SVT Performance Pack to account for the extra ~1qt of oil that will generally be stuck in the oil cooler system and never be fully drained. so, the top of the hash is full if you have the performance pack? I guess once the car is started the extra oil circulates and the oil will drop down into the hash. Link to comment Share on other sites More sharing options...
Bookwyrm Posted May 9, 2014 Report Share Posted May 9, 2014 The top line of the hash should be Full on any mustang -- between the lines on the hash is OK, and below the bottom line of the hash is Low. Link to comment Share on other sites More sharing options...
