pue174 Posted April 11, 2014 Report Share Posted April 11, 2014 Sorry if this already been addressed, I looked and couldn't find answers I was looking for. I have the 750 hp whipple upgrade to my non super snake gt500 and was trying to find out what numbers you guys have been getting on the dyno. If some of super snake guys have dyno'd your stock 750hp, can you post your HP and TQ numbers? Thanks Link to comment Share on other sites More sharing options...
super hiss Posted April 20, 2014 Report Share Posted April 20, 2014 I hear people say it 10-15% less than crank, so figure 650rwhp and probably 625 tq bc it's a whipple and that's the least you're running Link to comment Share on other sites More sharing options...
pue174 Posted April 21, 2014 Author Report Share Posted April 21, 2014 I made 599 and 575 seems low, just wondering what everyone else was getting. Link to comment Share on other sites More sharing options...
KCMO-GT500 Posted April 21, 2014 Report Share Posted April 21, 2014 I'm making around 700rwhp with about 800 hp at the crank.....dynos are not perfectly repeatable from unit to unit, with varying conditions. But you can figure about a 12% loss from crank hp with these things on average. As a starter, most of the 500hp shelbys dyno'd about 440 hp at the rear. Your % loss probably drops a bit as you increase crank hp since some of the losses will not go up proportionally. If a car is supposedly making 750 crank hp, I would presume it to have about 650-660 rwhp under good conditions. Different styles of dynos also yield different results (ie mustang versus dynojet) Link to comment Share on other sites More sharing options...
KCMO-GT500 Posted April 21, 2014 Report Share Posted April 21, 2014 ....and for what its worth.....take the advertised hp from all of these kits with a lot of skepticism..........there are an awful lot of if, ands, or buts included with those ratings. The power is what it is......if you feel it is not high enough, then dig into what you can do to increase it....consider restrictions in intake or exhaust, and how the tune is set up (eg which octane rating did you use). Many sets include the ability to use multiple octanes, and the rated hp is based on the highest octane. Plus which throttle body you use makes a huge difference. Are you using high flo cats, or no cats.........you see where I am going with this? No one can really guarantee a certain hp from from a car unless they can control all factors, including how it is dyno'd. Link to comment Share on other sites More sharing options...
Robert M Posted April 21, 2014 Report Share Posted April 21, 2014 I hear people say it 10-15% less than crank, so figure 650rwhp and probably 625 tq bc it's a whipple and that's the least you're running ^^^^This sounds about right. When the 725's first came out with the 2.8 KB, multiple owners brought their Super Snakes to the dyno for test results, they all rear wheel hp'ed in the 632-638 range with the original cast iron exhaust manifolds and full oem exhaust forward of the Borla catback system that was added at Shelby as part of the upgrade. R Link to comment Share on other sites More sharing options...
osu823 Posted May 20, 2014 Report Share Posted May 20, 2014 650 HP; 2 Dynos. Made 680 with bigger fuel pumps that can actually get proper amounts of fuel to the car. It was 80degrees when it was dyno'd. I have AMR headers and no cats also. Link to comment Share on other sites More sharing options...
pue174 Posted May 23, 2014 Author Report Share Posted May 23, 2014 Thanks Link to comment Share on other sites More sharing options...
69iger Posted June 10, 2014 Report Share Posted June 10, 2014 Time ago following results for my 08GT500SS with 2.8H Kenne Bell: 735,4 DIN PS - 540,89 kW - 725,34 HP - crank - max. @6303 rpm 622,1 DIN PS - 457,55 kW - 613,59 HP - rw 890,1 DIN Nm - max. @4474 RPM On SuperFlow WinDyn V3.1 Juergen Link to comment Share on other sites More sharing options...
