bdparnes Posted May 24, 2007 Report Share Posted May 24, 2007 I recently bought a K&N Aircharger kit for my 2007 Mustang GT. I installed it and started up the car and it immediately said "Tire Pressure Monitor Fault" and wouldn't register Fuel Levels on the digital display (though fuel registered fine on the actual gauge). So I took the K&N kit off and re-installed the factory kit...and it now registers fuel levels just fine on the digital display but it still says "Tire Pressure Monitor Fault." Has anyone else had this problem? Or know how to fix it? Thanks Link to comment Share on other sites More sharing options...
Grabber Posted May 24, 2007 Report Share Posted May 24, 2007 I recently bought a K&N Aircharger kit for my 2007 Mustang GT. I installed it and started up the car and it immediately said "Tire Pressure Monitor Fault" and wouldn't register Fuel Levels on the digital display (though fuel registered fine on the actual gauge). So I took the K&N kit off and re-installed the factory kit...and it now registers fuel levels just fine on the digital display but it still says "Tire Pressure Monitor Fault." Has anyone else had this problem? Or know how to fix it? Thanks Check your tire pressure and go drive your car and the tire pressure fault should go away. Not sure on the filter deal. Oh ya...welcome to the board. Link to comment Share on other sites More sharing options...
bdparnes Posted May 26, 2007 Author Report Share Posted May 26, 2007 Thanks! I ended up letting the car sit overnight and for some magical reason when I started it up the next day there were no problems (with the stock intake). Does anyone know if there's some calibration or something that needs to be done when installing a cold air kit on the '07 GT's? And can anyone recommend a good one? Link to comment Share on other sites More sharing options...
