39Mustang Posted January 25, 2014 Report Share Posted January 25, 2014 For those who ordered these you know they came with NO instructions! Looking at the Shelby Billet Fuel Door then looking at the factory one and what do you need to be an MIT graduate to install this? Plus, my 2013 came with no gas cap inside so I guess Ford got rid of them. We see no way how you access the filler housing to even remove the factory cap and arm? The plastic cap around the fuel housing has no clips so before busting it I thought it would be better to ask first Also, does the Shelby door actually seal the fumes? Installing the Shelby Billet Fuel Door on my 2008 Shelby was so easy This should be the easiest mod to do yet it looks like I want to break it and be done with it... honestly, no instructions included is quite ridiculous Link to comment Share on other sites More sharing options...
mikeljgt500kr Posted January 25, 2014 Report Share Posted January 25, 2014 I had mine installed at SAI during the build, but I took a look at it. Of the dozen or so torqx looking screws around the outside ring, only 3 are real (all at about 120 degrees from each other, starting at the top) and go through to some nuts holding it to the body with a nylon washer under the nut. I don't know what the stock door bezel looks like or what holds it on, maybe somebody can explain. Yes, both my 2013 Fords have no filler cap, just a spring loaded "door" you push the gas nozzle through. The exterior door on my Raptor is not tight fitting at all, so it isn't there to keep fumes from escaping, hopefully that spring loaded door in the filler neck does that. Link to comment Share on other sites More sharing options...
cmcmotorworks Posted January 25, 2014 Report Share Posted January 25, 2014 You might try going on American Muscle, UPR, CJ pony etc. where they post instructions online for similar fuel door, less engraving. I've done this probably half a dozen times to install parts I bought from SAI which do not have instructions. Link to comment Share on other sites More sharing options...
mikeljgt500kr Posted January 25, 2014 Report Share Posted January 25, 2014 Here's a video of one, installation is at the end of it. Link to comment Share on other sites More sharing options...
cmcmotorworks Posted January 25, 2014 Report Share Posted January 25, 2014 Good Work Mike !!! Link to comment Share on other sites More sharing options...
Larry T Posted January 25, 2014 Report Share Posted January 25, 2014 If you are having any trouble I know Cobra99 has installed one on his 2013 GT500, just give him a PM and I know he would be glad to help in any way he can. Link to comment Share on other sites More sharing options...
cmcmotorworks Posted January 26, 2014 Report Share Posted January 26, 2014 I installed them on my 2011 GT500 and my wife's 2010 GT. Removing the old neck collar is the toughest part after the factory door is removed. Just make sure to use plenty of blue tape around the opening to protect the paint. I always use blue tape with a layer of duct tape on top just as extra protection from an unfortunate slip of a tool. Link to comment Share on other sites More sharing options...
39Mustang Posted January 26, 2014 Author Report Share Posted January 26, 2014 Here's a video of one, installation is at the end of it. perfect... this works thx Link to comment Share on other sites More sharing options...
Jimmy Sak Posted January 31, 2014 Report Share Posted January 31, 2014 I can attest that there is only 1 that will fit the widebody, the one they install at the factory. Different bolt pattern.....and I found out the hard way. There are instructions but they do not send them with the part, I had to call up Tim to get the PDF. Link to comment Share on other sites More sharing options...
mikeljgt500kr Posted January 31, 2014 Report Share Posted January 31, 2014 I can attest that there is only 1 that will fit the widebody, the one they install at the factory. Different bolt pattern.....and I found out the hard way. There are instructions but they do not send them with the part, I had to call up Tim to get the PDF. You are correct about the wide body, when I looked at mine and the various GT350 doors, I could see the typical ones they have do not fit. I was actually looking for another one, in black, do you know if they make one for the wide body? Link to comment Share on other sites More sharing options...
ageishecker Posted January 31, 2014 Report Share Posted January 31, 2014 You are correct about the wide body, when I looked at mine and the various GT350 doors, I could see the typical ones they have do not fit. I was actually looking for another one, in black, do you know if they make one for the wide body? They put a black one on my wide body. Link to comment Share on other sites More sharing options...
mikeljgt500kr Posted February 1, 2014 Report Share Posted February 1, 2014 I know, they asked me which when it was built, but I am now thinking I want to try the black. Any idea where you can get it and if you can get the one with "GT350" on it? Maybe I should ask Jer. Link to comment Share on other sites More sharing options...
39Mustang Posted February 1, 2014 Author Report Share Posted February 1, 2014 Finished install it was easy... SAI, if selling a product include the DIRECTIONS because you will need a drill I'll get better pics when outside but makes a big difference instead of all White Link to comment Share on other sites More sharing options...
mikeljgt500kr Posted February 1, 2014 Report Share Posted February 1, 2014 Nice! Link to comment Share on other sites More sharing options...
39Mustang Posted February 2, 2014 Author Report Share Posted February 2, 2014 my top rarely goes up so being FL dust is everywhere so have to wipe down the interior more often and yes because of the humidity I put the top up enough so it doesn't mildew. we got the Sunshine but it comes with humidity and with that mildew.. maybe if average 100mph will the mildew and dust fly off? lmao Link to comment Share on other sites More sharing options...
cmcmotorworks Posted February 2, 2014 Report Share Posted February 2, 2014 Looks good. I wish I was in Florida right now. I have 16 Pony's that need turning out. They tend to get a little stall sour after a long cold winter. Link to comment Share on other sites More sharing options...
39Mustang Posted February 2, 2014 Author Report Share Posted February 2, 2014 Looks good. I wish I was in Florida right now. I have 16 Pony's that need turning out. They tend to get a little stall sour after a long cold winter. 16 wow I thought I was high with 7 What do you got as always looking for certain ones? I'm planning to move in March so don't want to buy anything I got to move but for a few years now trying to find a 71 429 SCJ Mach 1 with a C6 automatic. Yes, they're out there but finding 4spd's and I'm looking for specific colors Link to comment Share on other sites More sharing options...
cmcmotorworks Posted February 2, 2014 Report Share Posted February 2, 2014 No 71s thru 78s. 66 coupe. A couple of low mileage pace cars, one still in factory plastic. Black 1982 GT under 1000 original miles, Red 86 GT vert 300 orig. miles. 3 low mileage 20th anniv. cars vert,t-top,sunroof all under 6000 miles. Other Gts under 5000 miles. 2010, 2011 Kona Blue GT500 super snake build done by yours truly. 2012 Race Red GT350, Several more. Always in the market. Also too many boats. Link to comment Share on other sites More sharing options...
39Mustang Posted February 3, 2014 Author Report Share Posted February 3, 2014 No 71s thru 78s. 66 coupe. A couple of low mileage pace cars, one still in factory plastic. Black 1982 GT under 1000 original miles, Red 86 GT vert 300 orig. miles. 3 low mileage 20th anniv. cars vert,t-top,sunroof all under 6000 miles. Other Gts under 5000 miles. 2010, 2011 Kona Blue GT500 super snake build done by yours truly. 2012 Race Red GT350, Several more. Always in the market. Also too many boats. I am selling my 1992 SAAC MKI Link to comment Share on other sites More sharing options...
Jimmy Sak Posted February 3, 2014 Report Share Posted February 3, 2014 I know, they asked me which when it was built, but I am now thinking I want to try the black. Any idea where you can get it and if you can get the one with "GT350" on it? Maybe I should ask Jer. As far as I know there is only the "Shelby" engraved version in both colors. The wide body "Shelby" version is available; perhaps you need to call for it? I believe the price was about 20 bucks more than the normal billet style. I dealt with Jer and Tim on this issue over the phone, so they know there is a difference. Link to comment Share on other sites More sharing options...
mikeljgt500kr Posted February 3, 2014 Report Share Posted February 3, 2014 Thanks, Jer says he is working on it for me. Link to comment Share on other sites More sharing options...
Jimmy Sak Posted February 12, 2014 Report Share Posted February 12, 2014 Thanks, Jer says he is working on it for me. Hear anything back Mike? Link to comment Share on other sites More sharing options...
mikeljgt500kr Posted February 12, 2014 Report Share Posted February 12, 2014 Yes, he gave me two contact names to call at SPP to help, it is ongoing. Link to comment Share on other sites More sharing options...
